usp440m-42lp psu
    Re: usp440m-42lp psu
    Perfect. What's the voltage at the points indicated in the picture?
      Bouncing around 00.3 to 00.7 that looks a bit suss
        Are you sure the fuse is ok?
        You measure AC, right?
          i did a continuity test on it, i took the fuse out of its holder
            Check input voltage directly at the connector. Sure it's there?
              Nothing. Extension lead is fine
                Well, then the problem is somewhere else. I don't have the TV in front of me, just the board. Check the connector/cable etc.
                  That's very strange. Is your multimeter working? What if you measure the AC directly at the wall outlet?
                    well the extension lead is working as i have just tried my belt sander on it. just going to have a look at a faulty rocker switch and the bit where the kettle lead goes in
                      There is also an EMI filter directly connected to the AC inlet of the TV. Maybe it's faulty. You could measure the output voltage at its terminals.
                        yeah just looking at that now
                          gonna have to give it a break tonite, will go over these bits tomorrow.
                            ok. good luck. Shouldn't be hard.
                              i have not tested it yet but it does smell a little
                                Ok, keep us posted about your findings. There is not much left to check.
                                In the meantime I will spend another evening on my board
                                  will do
                                    How did this work out for you? Was it the Filter?
                                      hi paul not had chance to test it yet, hopefully tomorrow
                                        ok so i just tested the filter there is no voltage at all at the filter, so have a new filter on order.
                                          Great. Good luck!
