usp440m-42lp psu
  • joehezzer
    • Jul 2012
    • 251
    • England
    #81
    Re: usp440m-42lp psu
    my fault lol still learning . Outter pins read 02.2v dc the inner oned read 03.5v Ac
    • paulstef
      • Dec 2013
      • 724
      disconnect AC. check the two big white resistors. they are probably open.
      • joehezzer
        • Jul 2012
        • 251
        • England
        #83
        R106 and R105 you mean
        • paulstef
          • Dec 2013
          • 724
          yes.
          I will only have the board for a few more days. if we can find out whats wrong today would be good.
          • joehezzer
            • Jul 2012
            • 251
            • England
            #85
            Ok cool going to remove board as I cannot acces it
            • joehezzer
              • Jul 2012
              • 251
              • England
              #86
              taken one out and i got the reading of 5.6ohms both are reading this
              • paulstef
                • Dec 2013
                • 724
                Ok, look. The AC voltage that comes in goes more or less directly to the two middle pins of the bridge rectifier. You have to find out where this path is interrupted. If you cannot measure AC between the middle pins of the rectifier it should be fairly easy to find out.
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  #88
                  Tnr101 and tnr102
                  • paulstef
                    • Dec 2013
                    • 724
                    Tnr101 and tnr102
                    I cannot guess what you want to say. They are in parallel with the AC voltage. You only need to look at what's in series . Which component can cause an interruption from AC in to the bridge rectifier. Just follow the path. Forget the relay, it only jumpers the white resistors, which you said are ok.
                    Simple resistor measurement will get you there
                    AC OFF!!
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      #90
                      AC OFF!!
                      ok, i see what you are saying, it can only be one of the components leading up to the bridge rectifier.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #91
                        So I have decided to change the components leading to the bridge rectifier.
                        • paulstef
                          • Dec 2013
                          • 724
                          Right ok test out put again and got 263v Ac atleast I have a reading this time lol
                          In this post you said you have AC input voltage. So replacing anything between AC IN connector and this point won't help you. There are only the resistors between this point and the rectifier (where you measured nothing).
                          You said the resistors are ok. So I don't see where replacing any parts will lead you.
                          You are either not measuring correctly or there is something else we don't see.
                          When measuring resistance from one of the middle pins of the bridge rectifier to the AC input pins, what do you get?? Then from the other middle pin of the rectifier, what do you get?
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #93
                            I measured the wrong resistors. I had the board the wrong way round, as there are 4 of them, I tested the wrong ones as I was rushing yesterday
                            • paulstef
                              • Dec 2013
                              • 724
                              Ok, so if the two white resistors or one of them is open there are other component that need to be checked. First of all the bridge rectifier.
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #95
                                I have changed the bridge rectifier to a known working one. So will check again later after me dinner
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  #96
                                  Originally posted by wills123
                                  i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
                                  http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
                                  it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... priceless
                                  ok so i gave in on trying to find out what was wrong with psu, and ordered the above psu popped it in this morning it works, for the sake of £30 with free postage i cannot moan cheers all that helped me fault find the old one, cheers paulstef
                                  • dicky96
                                    Need to buy buck regulator MP2329CGG but struggling to find supplier
                                    by dicky96
                                    Hi guys
                                    I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                    Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                    I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                    Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                    03-05-2021, 08:44 AM
                                  • Faileng
                                    Struggling with a soldering job, need help.
                                    by Faileng
                                    Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                    I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                    I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                    I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                    02-06-2020, 02:07 PM
                                  • TimScrawn
                                    A2337 820-02016-A Failing DFU mode
                                    by TimScrawn
                                    I have a very strange issue here. Customer was using Mac one day and stopped working when they went to use it the next day. I plugged it into my amp meter and I got 5v at 0.10amp.
                                    Checked all rails:
                                    PPBUS_AON: 12,3 V
                                    PP3V8: 3.79v
                                    PP3v3_AON: 3.29v
                                    PPDCIN_AON_CHGR_R: 5 V
                                    The very strange part of the issue is that I left the Mac on one side for a day, came back to it and reconnected everything. Connected the DFU cable to a WS machine and connected the charger. The Mac then booted to the login screen? I then logged in and because I was after...
                                    06-29-2025, 10:27 AM
                                  • Doesronnieevenlift
                                    Help a noob! Wson8 Pogo/Needle Adapters to read/Write
                                    by Doesronnieevenlift
                                    I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
                                    My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
                                    I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
                                    For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
                                    Apologies if this is the wrong subcategory....
                                    06-22-2025, 04:51 AM
                                  • DiamondTech61
                                    Medion Erazer Deputy P40 no boot
                                    by DiamondTech61
                                    Hi guys im struggling with a medion erazer deputy p40 laptop, it just hangs on the erazer logo screen, i have found the ssd faulty and replaces it but still the same fault, i have reset the battery, restored bios to defaults, tested with different ram, taken ssd out completely, i have even had a go at booting memtest x86 but its always hanging on the logo. The usb stick does flash at the start like its reading it but then nothing, any ideas??? could it be a BIOS issue?
                                    06-18-2025, 01:45 AM
