What is the correct way to measure PFC voltage, I have a Hitachi Plasma Im gonna start trouble shooting.
How to measure PFC (Startup) Voltage?
Tags: None
Re: How to measure PFC (Startup) Voltage?
Across the large 450V capacitors.
Note - PFC voltage is different voltage from the startup capacitors voltage often found around PFC ICs.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
+ probe top of cap, - probe to ground? Forgive my ignorance, not trying to spark 450v.Comment
across cap, so red probe on positive and black probe on negative, you do not want to probe relative to ground as that is a meaningless reading.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Are you sure those are main filter caps for the PFC Voltage booster circuit?Never stop learning
You did have the set switched on ?
What is the model number of the set
Post a good picture of the board straight on.Last edited by selldoor; 02-26-2014, 03:52 PM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Those are the VSUS caps for the sustain voltage, I think.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
To me, it looks like the sub PSU generates the PFC voltage, so you could try probing across that black/white cable running between the two.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Verify if the Black wire does go to the Positive leg of the cap and the White wire does go to the Negative leg of the caps, otherwise it can be HOT (Black) and Neutral (White) for primary side of the circuits.Never stop learning
Verified black wire is ground, 380 v steady at the black/white plug. Caps to the right of plug are still not showing anything on the meter.Comment
That reading sounds about right. What's the actual fault with the unit?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Power tv up, fans/boards come on for about 4 seconds, goes into protection. Flashing blue led on front, no prime on the screen. Main supply has a high pitched sound coming from it.Comment
Count the blue blinks, error code should be in service manual.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yep, already did that,according to manual xsus bad. I have disconnected everyboard only way I can get it to fully power up and stay running is to disconnect c613 plug from main digital to power supply. Main board is good though, tried it another tv, operates as it should. I assume if xsus was bad, the tv would power up with out shutting down with the x disconnected.Comment
You assumed wrongly... sorry, this is a Hitachi, and they are terrible for repairability!
If a Hitachi plasma has an XSUS fault it will also give an XSUS fault with the board pulled. Great way to confuse.
You will probably find a bad FET on the XSUS.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by rddubeHello friends,
Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I... -
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?...06-25-2025, 07:19 AM -
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
I decided to verify that the batteries were... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... - Loading...
