How to measure PFC (Startup) Voltage?
  • topfli8979
    • Oct 2012
    • 311
    What is the correct way to measure PFC voltage, I have a Hitachi Plasma Im gonna start trouble shooting.
    Re: How to measure PFC (Startup) Voltage?
    Across the large 450V capacitors.
    Note - PFC voltage is different voltage from the startup capacitors voltage often found around PFC ICs.
    • topfli8979
      • Oct 2012
      • 311
      + probe top of cap, - probe to ground? Forgive my ignorance, not trying to spark 450v.
        across cap, so red probe on positive and black probe on negative, you do not want to probe relative to ground as that is a meaningless reading.
        • topfli8979
          • Oct 2012
          • 311
          How do you test it in circuit, tv powered up? I get no reading across these large caps.
            Are you sure those are main filter caps for the PFC Voltage booster circuit?
            • selldoor
              Slow Learner
              • 7870
              testing in circuit is what you have just done?
              You did have the set switched on ?
              What is the model number of the set
              Post a good picture of the board straight on.
              • topfli8979
                • Oct 2012
                • 311
                I figured that is what he meant about "across the cap" being in circuit. Set does not power up fully, goes into protection after about 6 seconds. I get NO voltage through out the power up process on my meter. Model # P60x901
                  Those are the VSUS caps for the sustain voltage, I think.
                  • topfli8979
                    • Oct 2012
                    • 311
                    From what I can find on the interweb, the sub power supply is on left, main on right.
                      To me, it looks like the sub PSU generates the PFC voltage, so you could try probing across that black/white cable running between the two.
                        Verify if the Black wire does go to the Positive leg of the cap and the White wire does go to the Negative leg of the caps, otherwise it can be HOT (Black) and Neutral (White) for primary side of the circuits.
                        • topfli8979
                          • Oct 2012
                          • 311
                          Verified black wire is ground, 380 v steady at the black/white plug. Caps to the right of plug are still not showing anything on the meter.
                            That reading sounds about right. What's the actual fault with the unit?
                            • topfli8979
                              • Oct 2012
                              • 311
                              Power tv up, fans/boards come on for about 4 seconds, goes into protection. Flashing blue led on front, no prime on the screen. Main supply has a high pitched sound coming from it.
                                Count the blue blinks, error code should be in service manual.
                                • topfli8979
                                  • Oct 2012
                                  • 311
                                  Yep, already did that,according to manual xsus bad. I have disconnected everyboard only way I can get it to fully power up and stay running is to disconnect c613 plug from main digital to power supply. Main board is good though, tried it another tv, operates as it should. I assume if xsus was bad, the tv would power up with out shutting down with the x disconnected.
                                    You assumed wrongly... sorry, this is a Hitachi, and they are terrible for repairability!
                                    If a Hitachi plasma has an XSUS fault it will also give an XSUS fault with the board pulled. Great way to confuse.
                                    You will probably find a bad FET on the XSUS.
                                    • rddube
                                      Lenovo L490 Ram voltage circuit malfunction
                                      by rddube
                                      Hello friends,
                                      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                      Today, 04:41 PM
                                    • Fernon@Repair
                                      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                      by Fernon@Repair
                                      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                      VCCIO voltage ok
                                      VCCSA Voltage OK
                                      VCCPLL Voltage OK
                                      Ram Voltage ok
                                      RamVTT OK
                                      VPP 2.5 OK
                                      But No Core Voltage
                                      and i want to this vrm ic datasheet or pinout (ISL69269)
                                      anyone have this ic pinout voltages?...
                                      06-25-2025, 07:19 AM
                                    • quickname
                                      Cyberpower 1500AVR UPS repair
                                      by quickname
                                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                      I decided to verify that the batteries were...
                                      11-12-2023, 09:57 AM
                                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                      by sam_sam_sam
                                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                      Now...
                                      06-09-2024, 10:57 AM
