Sony XBR-75X800G - Android start up only and dark blue screen
Do you really want to give up? ALL is not tried yet, now listen up, DO or at least try to do the update/re-pair, no joy then DO these tcon tests, a video is worth a million words. This is one of those youtubers that knows what hes doing, just follow his lead, lets see what we get.once again this is tv repair not brain surgery, these tests are really not that hard, specially with a good how to video right there: https://www.youtube.com/watch?v=P5uD1tzMdUs
Ok thanks for trying and appreciate the patience. If you have doubt with the standalone test, which Im guessing that means you think either A its the panel or B my skills at the test, then theres no point in going further and Ill scrap it.Leave a comment:
lol... common.... sorry man. i have doubt right now with yours standalone test and this small things... please seek help from around before you cause unforgivable damage to the setLeave a comment:
Diah, you are referring to that panel in the first photo and not to the gold ribbons in the second, correct?2 PhotosLeave a comment:
turn on tv with signal mean fed the tv with cable or areal or hdmi signalLeave a comment:
under the speaker you will have plate on each side you need to remove them then you will have access to the panel buffer boards which the 2 ribbon cable from T-con connected to them... take look at the middle you will find U ribbon cable connect 2 pieces together on each sideLeave a comment:
So I removed the speaker and there is nothing behind it. Its just 2 wires coming off it.
What is the panel buffer boards?
Im sorry, Im getting lost at what yu want me to doLeave a comment:
"If the set doesn't auto turn on, then press the power button. In rare cases, the board does not require to be paired. If the set turns on and shows picture, you are done, no need to pair the mainboard!"
Im assuming since I plugged in the MB and it went thru the process and allowed me to perform a factory reset it, it has paired?Last edited by nomoresonys; 08-27-2024, 12:59 PM.Leave a comment:
Ill try this now, but what is meant by " turn on the TV with signal " ? Do you just mean to power up tv?Leave a comment:
​Leave a comment:
Firmware update directions there, looks like Nicks already put it on the usb so you can go straight to update procedure: https://www.sony.com/electronics/sup...tware/00262031Leave a comment:
remove the speaker and let see the panel buffer boards.. on each side you have at the middle U ribbon... try disconnect one a time and turn on the TV with signal to wake up the Soc GPULeave a comment:
Oh and Nicks did send me a USB drive bac with my MB but no information with it. When I plugged into my computers and I checked the file name it was " upgrade_loader.pkg " I dont have a program on my computer to open it, but figure its something for the TV. I was going to call them today and ask about it. Bad thing is though, if its some kind of firmware updater or something, without being able to see anything on screen, I wont be able to do anything with it.Leave a comment:
just called Nicks, they said the USB was for pairing the MB back to this TV, so they sent me instructions on how to do and will perform that now.
yes original remoteLeave a comment:
Well the screen shows me nothing ( meaning cant see any message appear ) but I did hold down the remote power, tv shut off and rebooted, LED lights cycled, but no display.
Tried the unplug and hold manual button down for 30 seconds and plugged back in, and LED lights cycled but no display.
Tried a hard reset with the power and down buttons held, green lights faded in and out on little light below the TV, then let go, little light went to white, LED lights cycled, but no display.Leave a comment:
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by zukdjA new main board and power supply was installed on my TV last night, purchased the parts at ShopJimmy. I had no power before installing both parts. Now the TV powers on and I hear music as it cycles through a white-red-green-blue screen. I was thinking it may be a firmware mismatch with the parts however I am skeptical as to plugging in a USB stick with the newest firmware on it since I cannot do any user interaction since all I see is colors on the screen, will the firmware start and complete on its own once the USB is inserted or does it require user input? Someone told me it is in Purity Check...
by Adam RussWeird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
- Loading...
