sony kdl 32 bx 300 turns off and back on help
  • ivtec
    • Dec 2008
    • 1967
    Hi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Try a factory reset or self test.
    service manual here : https://servicemanuals.us/sony/tv/kd...l-32bx300.html
    Maybe the firmware is corrupted or the flash going bad? Take the batteries out of the remote and see if this new found magic stops.
    Edit: read this old thread: https://www.badcaps.net/forum/troubl...ndefined-state
    • ivtec
      • Dec 2008
      • 1967
      Thanks mate. It's funny that i took the back cover out and while was out tv worked fine. Also i put the Tv in my storage and today went to try to turn it on and off and so far it did not turn on by itself .
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Weird shit happens!
        • Diah
          • Feb 2013
          • 6494
          Weird shit happens!
          exactly... its want retired but owner refused ...lol
          cold joint solder
          • ivtec
            • Dec 2008
            • 1967
            cold joint solder
            Hi mate some times it does it again, you say cold joints ,where mate in the mainboard ? https://www.shopjimmy.com/hisense-ma...for-55r6095g5/
            • nomoresonys
              • 12306
              • U.S.
              Doesn't a wonky eeprom give those symptoms also?
              • Diah
                • Feb 2013
                • 6494
                dear friends,,, yours set Sony.. and yours links refer to hisense all in one boards..... your case at PSU not MB
                • ivtec
                  • Dec 2008
                  • 1967
                  Sorry mates my bad;https://www.shopjimmy.com/search.php...032%20bx%20300
                  • SluggerB
                    2 LG TV's in same room, one remote turns both on or off ...
                    by SluggerB
                    I have 2 LG TV's in a room. It seems the power button is the only IR button on the remote, since pressing the power button on either remote turns on/off both TV's. Once turned on, the remotes only work on their respective TV's (that is a setting I set on each, I gave each it's own ID)
                    I have "solved" the issue by putting electrical tape over most of the sensor on front of the TV's so they dont pick up the other remote's signal, but I was wondering of there was a more elegant electrical fix that could be done on the board of the remote and/or TV to make the remotes...
                    05-22-2022, 02:27 PM
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                  • thetonywarren
                    Samsung un32j5205af turns on, but needs to have power disconnected to power back on
                    by thetonywarren
                    SAMSUNG UN32J5205AF
                    Wierd issue. Set turns on, works as normal, then turn off, and when you try to turn back on, it wont. The backlight comes on, but doesnt boot up. You need to disconnect power supply from back, then reconnect it, and then the set works again. somewhat annoying issue.
                    Where to start? I can provide any videos or pictures needed to troubleshoot.......
                    11-15-2022, 09:23 AM
                  • JohnML1975
                    Falcon FF32S53 turns off by itself then will not turn back on unless you wait
                    by JohnML1975
                    Dear Forum members
                    I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
                    I will upload some photos and share my trouble shooting steps so far
                    07-20-2025, 12:28 AM
                  • Titus6
                    LG OLE65C1 Stand-By issue
                    by Titus6
                    I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                    However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                    I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                    01-31-2025, 04:01 PM
