Toshiba LED TV, blank screen
  • Carmine JP
    • Feb 2015
    • 5
    • US
    #61
    Re: Toshiba LED TV, blank screen
    Cut lead
    • Carmine JP
      • Feb 2015
      • 5
      • US
      #62
      Cut lead again
        Originally posted by Carmine JP
        Well I cut the lead that goes to pin 15, and the problem is still there. Any assistance would be GReAT
        Can you please report the DCV Voltage readings of all the pins?
        BTW, if the BL-ON (pin 16) is not present, removing pin 15 (dim) is not going to make backlights come on.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4977
          • New Zealand
          #64
          For future reference, it is much better if you cut the flexible wire on the plug rather than the pin on the socket - wires are much easier to join back together again.
          In this case you will need to get a whole new socket if you wished to rejoin them.
          -David VanHorn
          • tibimakai
            • Jan 2012
            • 3680
            There is still no remedy, for this problem?
            There is a TV on CL and I'm not sure, if I should pick it up or not.
              If you're not prepared to take the risk then you should probably avoid it. LED TVs are proving real hard to fix due to LED array failures and LCD panel faults. I've also found that, at least around where I live, they don't command that much of a premium over conventional LCD TVs, so they're not worth much to me either.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #67
                Hard to resell led tvs around my area too, argos the minute are doing 32in hd ready proscan sets £139.00 so trying to sell any repaired sets for a resonable mark up is hard imo at the minute.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have realized that already, that is why I start repairing other type of devices as well.
                  But still, if I find a nice TV, I can still make a little bit of money, but for sure not like in the past.
                  • TechShui
                    • Jun 2011
                    • 148
                    Originally posted by MDluffy
                    FW update - well, finally got the FW update working... definitely helped that I could see the screen in order to select 'yes'... learned something maybe useful to others... initially used a usb hanging around... didn't work. It was 8GB and formated NTFS. Found an older usb, 512MB (website said 256MB min) and formatted FAT32. bingo, worked like a champ. results? time will tell, although I have to now figure out how to get the channels happy... some are proper aspect ratio for 46", and other channels seem stuck on low quality with view not going out to sides... will keep all posted, thanks MDLuffy
                    Where did you download the firmware update from?
                    • james1095
                      • May 2015
                      A very common cause of this symptom in these sets is failure of the LEDs themselves. They fail shorted which is unusual for LEDs and this causes the inverter to shut down. Unfortunately the LED strip is buried inside the panel and is a real pain to access. You can test easily though, the strip is wired as four series strings of 16 LEDs with a common anode and there are test points near the connector on the inverter. Power on the set while watching the voltage between common and each of the four cathode test points. It should show about 100VDC on each one, if one or more is significantly lower, you have one or more shorted LEDs in the backlight strip.
                      It isn't unique to Toshiba, some other TVs use the same Samsung LCD panel.
                      • alfredomfr1
                        • Oct 2014
                        • 318
                        • usa
                        #71
                        I have a Toshiba 46L5000U with same problem: turn on, Toshiba logo for 1 second and dark screen after that.
                        I disassemble the panel and found it 2 led shorted.
                        Ordered in ebay for 24.99, will post again when arrive.
                        • alfredomfr1
                          • Oct 2014
                          • 318
                          • usa
                          #72
                          LED received and installed, LED strip ok now, but still Toshiba logo for 1 second and dark screen.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4977
                            • New Zealand
                            #73
                            Did you verify they all light up even if for just one second? Are you sure you did not miss any shorted or open LEDs?
                            -David VanHorn
                              Did you replace the LEDs or the LED strip?
                              Do you also see the DCV at the DIM goes up to >3V and then drops down?
                              • alfredomfr1
                                • Oct 2014
                                • 318
                                • usa
                                #75
                                I replaced 2 shorted LED and yes DIM goes up to >3v and then drops down to 0.2v
                                • alfredomfr1
                                  • Oct 2014
                                  • 318
                                  • usa
                                  #76
                                  You right Agent24 found one more that not light up but is not shorted or open, have same reading that the good ones.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4977
                                    • New Zealand
                                    #77
                                    If it doesn't light up something must be wrong with it. Maybe it has a broken solder joint or broken\burnt trace? Or maybe it's only failing under load. Try replacing it anyway?
                                    I would assume if that one is not working for whatever reason, then it is the cause of the backlight getting shut down.
                                    -David VanHorn
                                      Try disconnecting the DIM wire and see if the backlights will stay on.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have the same TV, but it runs for hours and eventually, the backlight goes out.
                                        TV still works, sound is working and with the flashlight, I can see the image.
                                        Installed the firmware from Toshiba site, but did not fix the problem.
                                          You can reduce the backlights level to about 75% of max, I was able to keep it running all day, otherwise the backlights will shutdown after about 2 hours.
                                          This one has the PWM control line problem, I disconnectd the PWM line and use the resistor to drop the analog dimming Voltage down to keep the backlights on.
                                          http://s807.photobucket.com/user/bud...?sort=3&page=1
                                          • Mad_Science
                                            Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                            by Mad_Science
                                            I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                            03-01-2024, 05:05 PM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • Chrissygizmo
                                            Panasonic TX-48CX350B backlights but white screen , blank screen
                                            by Chrissygizmo
                                            Hi all, I’ve got a problem I hope someone can help me fixi.
                                            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                            01-11-2025, 03:18 PM
                                            09-06-2024, 05:27 AM
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
