Toshiba LED TV, blank screen
  • hdguy
    • Sep 2014
    • 49
    Re: Toshiba LED TV, blank screen
    I have the Toshiba 46L5200U, Manufacturer Date Feb 2012.
    Disconnecting DIM didn't work for me (neither the 14 pin on the power board nor the 15 pin on the control board; yes, I read that is basically the same thing, but I wanted to be sure). Not even intermittently. Having read this entire thread (and several others), pulling a pin is clearly a fix for some of the TV's - just not mine.
    Since my symptom is intermittent (but easy to replicate), I was able to adjust the Backlight setting (Menu --> Picture --> Picture Settings, Backlight) to keep the TV running.
    Setting Backlight to 0 (zero) kept it going all morning. Setting Backlight to 40 killed it right away. I'm now about 1.5hrs into Backlight setting at 30, and it has stayed on. The default factory setting is 70 (both before and after the firmware update, which I have applied: http://support.toshiba.com/support/m...eeText=3308679 ).
    To me, this is still a temporary fix.
    My hypothesis:
    Remove the LCD panel and replace the Toshiba 2012SGS46 LED Light Strip Bar & it will be like new. (at which time, I would probably change my Backlight setting to 50, not 70, the default).
    Any thoughts?
    Feedback welcome and wanted.
    • hdguy
      • Sep 2014
      • 49
      UPDATE: Backlight setting @ 30 started causing problems now. I was able to make it through a 2 hr movie on 20, but considering the goal for this TV is for gaming, I decided to order a replacement LED strip.
      • hdguy
        • Sep 2014
        • 49
        does anybody have a spare cable ribbon from the led driver to the backlight?
        I was a little to rough on the one in the tv & now I've broken the connector
        • hdguy
          • Sep 2014
          • 49
          I was a little too rough on the one in the tv & now I've broken the connector
          • Agent24
            I see dead caps
            • Oct 2007
            • 4962
            • New Zealand
            #145
            Try eBay?
            -David VanHorn
            • hdguy
              • Sep 2014
              • 49
              SUCCESS!
              I tore apart some broken earbuds for the super thin wires and fired up my solder iron, to rebuild the wire harness/connector that I broke when replacing the backlight.
              With the new backlight installed, the TV is no longer flickering & dying.
              Thanks everyone for your help with the repair, and the great information!
              Tim
              • pnlonestar
                • Jun 2018
                I am so thankful for these posts. My solution was covered in post #32. When dealing with the wires, I found that it was easier to cut them in the middle, strip them, and then splice them together. Pulling them out seemed like more work that could possibly damage the connection.
                After trying every variation possible with wire 14, 15 and 16, the solution was simply cutting wire 15 &16, then crossing them. I understand that this is a bypass fix, but it's all that I am wanting to do for now.
                • Mad_Science
                  Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                  by Mad_Science
                  I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                  03-01-2024, 05:05 PM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • Chrissygizmo
                  Panasonic TX-48CX350B backlights but white screen , blank screen
                  by Chrissygizmo
                  Hi all, I’ve got a problem I hope someone can help me fixi.
                  I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                  01-11-2025, 03:18 PM
                  09-06-2024, 05:27 AM
                • dicky96
                  HP Elitebook Screen blank - backlights but no image
                  by dicky96
                  Hi guys
                  I'm trying to fix this laptop screen
                  Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                  OK so I have the original screen which works but has lines across the bottom quarter of the screen
                  I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                  04-28-2021, 07:30 AM
