Viewsonic N4785P TCON Issue
  • Slow_Frank
    • Jan 2014
    • 9
    My viewsonic went all bright white / negative, so after reading here it looks like a TCON issue, I measured all the gamma voltages and other voltages. I used the spreadsheet made by tom66 and it seems the voltages are all out, AVDD (3.27), Vcom(1.63), Von(0.7), Voff(2.48). Vin seems a little low (11.5V) Is there any further way to troubleshoot this, or should I just board replace?
    Thank you.
    Re: Viewsonic N4785P TCON Issue
    Either replace the AS15 or new board.
      The gamma is bad. But I would check you are testing the other voltages OK, because I would expect AVDD that low to result in a basically fully dark image with maybe some detail visible. Also, the top gamma voltage reference usually comes from AVDD so you could not have 13V gamma with low AVDD. I would try unplugging the white ribbon cables at top of the panel, one at a time, and see if your voltages come back.
      • Slow_Frank
        • Jan 2014
        • 9
        Tom you are correct, I took VDD on the PCB to be AVDD and looks like on my board it is simply labeled VDA, it measures 13.7V. (attached)
        The gamma IC is an i7868A, which appears to be an intersil chip, but I can't find any datasheets on it, does anyone know if an AS15 is pin compatible?
          from another user:-
          as15-f=as15-g=as15-u= as15-hf=tsl1014if=hx8915a=ec5575=sl1015i=rm5101=aat7200 = all are equal.
          https://www.badcaps.net/forum/showthread.php?t=33806
          Do not know if others will work, you'd have to compare datasheets.
          • Slow_Frank
            • Jan 2014
            • 9
            Cut the legs off the IC with a razor knife, swept the legs away with soldering iron. Had someone hold the IC and hit the bottom of the PCB with a microtorch. Everything came away easy. Seems like this chip was poorly soldered to the thermal plane, possibly why it failed.
            • Slow_Frank
              • Jan 2014
              • 9
              Couldn't find the datasheet for the i7868A, so I figured I would try a AS15, waited a month for an ebay special, soldered it on. This is what I got, also it got really hot fast, so it would seem they are not pin compatible to the i7868A. (I have since ordered a i7868A). I soldered the AS15 thermal pad by hitting the bottom of the PCB with a 250W soldering gun, seemed to work ok.
              • cagri
                BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                by cagri
                I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                PMIC: iML8940
                There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                Input 12v, fuse ok
                DVDD1V2 = 1.2v
                DVDD1V8 = 1.8v
                DVDD3V3 = 3.3v
                VGL = -7v
                **VGH = -0.3v
                **VCOM0, AVDD, HAVDD = 0v
                SWBK1 = 3.3v
                SW1 = 12v
                VGH to GND resistance is 500kohm as expected
                Readings are same after I disconnected the two cables from TCON to panel...
                07-27-2023, 09:48 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • thelankanguy
                Sony KD-55X9000F TCON Issue
                by thelankanguy
                The TV shows a black screen with no image.
                TCON ribbon connectors were disconnected individually for image and there was no half image even.
                Later both ribbons were disconnected and TCON voltages were tested.
                12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                There is also a short to ground in this circled inductor.
                Is this a TCON issue or something else ?...
                12-13-2024, 12:27 AM
              • EazyBone
                Vizio P759-G1, Tcon issue?
                by EazyBone
                Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                Any help appreciated
                https://youtu.be/tPeV2Q7TXIQ?feature=shared
                03-22-2024, 03:25 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                Yesterday, 06:04 PM
