Vizio E472VLE vs VIZIO E3D470VX LCD SCREEN
  • ecking767
    • Oct 2009
    • 492
    I have two Vizio 47" 120hz LCD TVs, the E472VLE good LCD screen and bad main board and the E3D470VX with a crack LCD screen and good main board, but E3D470VX is a 3D TV. I have swap the good LCD screen to the E3D470VX.
    Picture is clear on the E3D470VX TV using the E472VLE panel. Both panels have almost the same part number, my concern is are there is difference between the two panels?
    E472VLE PANEL # LC470WUH (JE) (A1)
    E3D470VX PANEL # LC470WUH-(JE) (P1)
    NOT SURE on the last four digital of the part number and what it means
    The 3D function WORKS on Direct TV with 3D glasses
    Im I ok doing this?
  • patrax
    • Feb 2014
    • 33
    Re: Vizio E472VLE vs VIZIO E3D470VX LCD SCREEN
    Imho as long as voltages match up give it a try. There is probably a different scaling process on the the 3d mainboard that drives that panel but the 2d side is most likely the same. Should plug right up. I would "Frankintv" it together carefully tho and make sure upon startup nothing smokes, just be prepared for anything if you do try it. I think it should play fine but who knows?
    • jimmyk
      • Sep 2012
      I have done the same swap , but have never been able to see 3d, just blurred double images. still trying though.I dont have cable or 3d blu-ray but have tried vudu 3d trailers and youtube 3d. Glad to here someone has. Any suggestions on other sources ?
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • paqman
        Vizio M60-C3 black screen
        by paqman
        So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
        So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
        03-02-2024, 04:37 PM
