Th-42px80ba
    Re: Th-42px80ba
    1st I'd check the SUB5V, SUB3.3V on main board; close pictures of main board?
    • sordids999
      • May 2013
      • 2152
      Re: Th-42px80ba
      pictures attached
        Re: Th-42px80ba
        If you need full schematic of A board, see service manual.
        SOS10 checks:
        - DTV9V
        - MAIN9V
        - SUB5V
        - SUB3.3V
        - MAIN3.3V
        - BT30V (via SOS10 ckt)
        - SUB5V (again, via SOS10 ckt)
        - DTV9V (again, via SOS10 ckt)
        You might be able find point TPS0S on A board which will go HIGH (>3V) when there is an SOS10 event caused by the last three, otherwise, you need to check the other voltages directly.
        Note, TP is on bottom of board - so you will have to lift board up with cables attached and test it there.
        • sordids999
          • May 2013
          • 2152
          Re: Th-42px80ba
          Can any one point me to a service manual please
            Re: Th-42px80ba
            Try elektrotanya.
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              Re: Th-42px80ba
              Service manual
              Liberating magic smoke one part at a time
              • sordids999
                • May 2013
                • 2152
                #27
                Re: Th-42px80ba
                ok so to measure these tom do i need to keep turning the tv on and off because at the moment i cant measure any voltages on the main board ?
                  Re: Th-42px80ba
                  It would need to be a lot of on and off.
                  • sordids999
                    • May 2013
                    • 2152
                    #29
                    Re: Th-42px80ba
                    tom im starting to measure the A board but at the moment if i just leave the cables going from the P board to the A board im getting the correct voltages from the psu and its not clicking no more
                    • tw2005
                      • Oct 2011
                      • 6458
                      Re: Th-42px80ba
                      have you tried this. Hook all the boards up and try disconnecting P6/P7
                      To troubleshoot a PDP TV that is shutting down and the power LED blinks 10 times:
                      Isolate the SC and the SS boards (They may cause a 10 blinks shutdown). Disconnecting P6
                      and P7 allows for only the panel drive section to be driven. If the LED on the SS board and
                      the LED on the SC board are lid, then the SS and the SC boards are OK and the A board is
                      suspected to be defective
                      If the LEDs on the SS and SC boards are not lid, then isolate them one at time.
                      If the SS and SC boards are OK, then the P board may be defective.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Re: Th-42px80ba
                        I've done it again, don't think this has a D-board in which case don't expect it to work?
                        • sordids999
                          • May 2013
                          • 2152
                          #32
                          Re: Th-42px80ba
                          no havent tried this yet but if i connect the following back on the A board but leave the following connections not connected the ss and sc boards are lit up along with the P board giving correct voltages
                          • tw2005
                            • Oct 2011
                            • 6458
                            Re: Th-42px80ba
                            I'm thinking leave A52 off but what's the large ribbon? Any evidence of damaged SD or foreign object in there shorting 3.3V line. Measure resistance between pins 1 and 2 of that A52 cable.
                            • sordids999
                              • May 2013
                              • 2152
                              #34
                              Re: Th-42px80ba
                              the large ribbon connects to the buffer boards BUFFER BOARD TNPA4642
                              • tw2005
                                • Oct 2011
                                • 6458
                                Re: Th-42px80ba
                                So try hooking everything up normally but leave a52 off, still would like resistance check at cable a52 1-2
                                • sordids999
                                  • May 2013
                                  • 2152
                                  #36
                                  Re: Th-42px80ba
                                  ok so while doing a few tests on A52 for tw2005 now i have the screen working but still cant use A52 thats still disconnected
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Re: Th-42px80ba
                                    well you have found the problem if it's working with a picture. The SD socket or GS board has shorted the 3.3V line which is one of the several voltages Tom had on the list to check.
                                    glad you like to experiment if this is the case, cut the fault finding down real fast.
                                    It is running with a picture ? yes?
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      #38
                                      Re: Th-42px80ba
                                      yes picture working but A52 still disabled
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Re: Th-42px80ba
                                        Well that's great mate a TV minus a SD reader , no biggy but cheap as chips to buy or remove the assembly and have a close inspection of it. may be salvageable and we have read of kids depositing coins in there.
                                        No major boards or expense
                                        One quick example, not sure if revision is critical but yours is Rev AE
                                        http://www.ebay.co.uk/itm/Panasonic-...item3f20a00071
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Re: Th-42px80ba
                                          You gotta put a pic of it running, that's the trophy piece
                                          • ferah831208
                                            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                            by ferah831208
                                            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                            03-18-2025, 01:18 AM
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • Stefan Steff
                                            HP Elitebook 840 G5 strange behaviour, need ideas...
                                            by Stefan Steff
                                            I finished my work for this year, so I'm free until January 6th.
                                            My last task it's unresolved and I'm looking for ideas for the return in January.
                                            So what's about...
                                            This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                                            My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                                            No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                                            The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                                            12-24-2024, 05:50 AM
                                          • CraigR
                                            Hp x360 15-u499nr power light flashes continuously.
                                            by CraigR
                                            I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                            09-16-2024, 06:12 PM
