T-CON Check Spreadsheet
  • nae8ean
    • Dec 2020
    • Philippines
    #41
    Re: T-CON Check Spreadsheet
    Originally posted by tom66
    Excel isn't hard, it's just equations and overly-complicated IF-equations (just click any cell to view the formula!) I did it in openoffice because I don't have a copy of Excel.
    The voltage has to increase OR decrease, in other words, differential voltage from point to point, the sign of the number needs to stay the same. Also, the symmetry test mirrors the voltages around VCOM (AVDD/2 or mid point average of gamma voltages) and sees if they match up. The symmetry test is an additional test, both should be done. It's a lot harder to do in your head. If either of these fail, the result is a guaranteed fail.
    Note -- the Detailed Results tab is more of an internal debug tab -- you should look at Summary for overall conclusion.
    New version coming soon with improvements and bug fixes.
    how about this flickering screen with horizontal line
    INPUT 12.47V
    VGH 30.34V
    VGL -9.50V
    AVDD 16.30V
    VCOM 6.90V
    VSS -9.16V
    WP INV 3.39V
    • neilc6
      • Nov 2015
      • 1550
      Flickering/double images and horizontal lines are panel problems but may be repaired with a workaround using the tape cutoff method.
      https://techhometravel.com/repair-of...lines-on-a-tv/
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
      • maxim2511
        LG 55EC930V OLED - swich on swich of no screen
        by maxim2511
        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
        Then I get an idea to take it apart and clean boards from dust.
        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
        05-14-2021, 02:21 AM
      • alltvrepairs
        Lg TCon test pins for screen test
        by alltvrepairs
        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
        Appreciate your help....
        06-13-2025, 06:33 AM
      • dreico33
        TL866 II Plus Check ID Error on various IC
        by dreico33
        Hellow guys , i really need your help here.
        Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
        11-04-2024, 03:13 PM
