LG OLD55CX6LA TCON Short - Help Identifying Component
  • spookt
    • Apr 2022
    • 4
    • United Kingdom
    Hi Folks
    I've got a friend's LG OLED on the bench (well the dining table given the size of it!). It immediately powers off when turned on and sits in standby. PSU voltages are good and after disconnecting the TCON board there is stable 12V and 22V coming out of the PSU board.
    Hunting around the TCON board there appears to be a shorted power rail (DVDD09_CORE) but I'm having issues identifying the component which is shorted. I've attached a picture. It's sitting before the coil so I'm assuming it's a MOSFET of some description, but the markings I can make out don't seem to match up. Under the scope it's marked 2J = L2M. I can't easily find anything with that designation. I know I can buy a 2nd hand TCON board for cheap, in fact I have one coming, but it annoys me that I'm potentially going to junk a perfectly good card for the sake of a $1 part.
    The TCON part number is 6870c-0852A.
    Any clues?
    Thanks!
  • Diah
    • Feb 2013
    • 6399
    did you make the test on the IC U21 while the panel disconnected from T-CON?
    • R_J
      • 9558
      U21 seems to be a Richtek RT6257BHGJ6F
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        be clear... what strange noting is 2J = L2M? Have you added "="?
        the tv model seems wrong..
        • adamok7
          • Feb 2023
          • 20
          • Kazakhstan
          You are 100% right.
          • lotas
            • Jan 2016
            • 4668
            • Russia
            Everything is correct, you need to know the labeling of the manufacturers.
            • spookt
              • Apr 2022
              • 4
              • United Kingdom
              Thanks for everyone's help! Definitely wouldn't have got there on my own!
              Yes, apologies - I missed a D from the model number should be OLED55CX6LA
              ​Cheers
              • Repairtechlcd
                • Nov 2013
                • 12
                • Malta
                Did you desolder the I.C to confirm that it's s/c and not some other component.?
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • duwane
                  MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                  by duwane
                  Hi All.
                  I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                  Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                  After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                  Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                  10-17-2023, 07:48 PM
                • sfernandes
                  Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
                  by sfernandes
                  Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
                  What I have done to try to isolate the issue so far:
                  The system powers on and stays on with...
                  01-23-2023, 06:03 PM
