Samsung LN46A550 Picture Issue
  • T-Rex
    • Feb 2014
    • 14
    Hi, I've got an issue with my LN46A550 that just started and I'm not sure if it's in the PS, TCON or Mainboard and was hoping somebody could dx this from pictures to at least have a high degree of confidence in what part to replace. I looked at the PS and did not see any obviously bad caps and I removed and reseated all 3 connectors on the tcon board with no changes. I also went into service mode and did a factory reset.
    Any idea what the problem may be based on the pictures? Thanks!
    Steve
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Samsung LN46A550 Picture Issue
    Because of the sharpness of the image, meaning it's not washed out, I'm gonna say main board. You can test the T-Con but I'm not able to tell you how. Highly unlikely to be PSU
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Wrong panel setting? At first I thought gamma chip but I looked up the tcon for this model and it doesn't seem to have the chip. So I would guess main board as well, try to access the factory settings and change the panel setting.
      • T-Rex
        • Feb 2014
        • 14
        Thanks for the comments so far. What do you mean by 'panel setting'? You talking the panel option or model setting in the Option Byte menu as in https://www.badcaps.net/forum/attach...&d=1354241249? How would that change on it's own? I'll go look at that.
        For reference the T-Con board is 35-D025860 and the main board is BN94-01723W.
        • Glitcher
          • Mar 2013
          • 673
          • USa
          Hmm, I'm wondering looking on the tcon model number, does your tcon have the AS15 chip? Can you post close up photos of the tcon?
          • tibimakai
            • Jan 2012
            • 3680
            It looks like a gamma chip went south.
            At shopjimmy, shows a A19-H16 chip.
            I have never replaced one of these yet, only the A15-F or G.
            You would be able to measure the test points on the T-con.
            They have to increase gradually from one test point to another.
            The test points are on the top center where it is labeled Gamma. Strat from 1, 2, 3...
            It there is one that is out od the line, then most likely the Gamma chip is bad.
            • T-Rex
              • Feb 2014
              • 14
              Yes, it looks like a A19-H1G chip (attached). So you are talking the 2 square pads of contacts by the ribbon cables labelled 1-9 and 10-18 on the opposite side? And these should be measured to ground. And you say the voltage on each sequential number should be higher, like pin 1 = 1 volt, 2 = 2 volts, 3 = 3 volts (examples)? Sorry, I'm not an electronics tech but I can sorta figure it out with guidance - thanks!
              • mmartell
                • Oct 2013
                • 3189
                Yes you got it. A plotted graph of the points should either be linear or slowly curving (tom ?) Any big deviations are likely chip malfunction.
                  In box marked GAMMA. Voltages will either INCREASE or DECREASE but not both. 1V, 1.5V, 2V, 3V, 4V, etc. and 4V, 3V, 2V, 1.5V, 1V are both OK. 4V, 2V, 3V, 1V, 1.5V is NOT OK. The voltages will not correspond with the numbers but will range from around 0V to 15V.
                  • T-Rex
                    • Feb 2014
                    • 14
                    This is what I got...
                    1. 15v
                    2. 12.9
                    3. 12.08
                    4. 11.2
                    5. 10.8
                    6. 10.43
                    7. 9.99
                    8. 9.35
                    9. 8.78
                    10. 6.42
                    11. 6.62
                    12. 6.66
                    13. 9.38
                    14. 9.41
                    15. 9.40
                    16. 4.15
                    17. 2.79
                    18. 0.48
                    So does that mean the gamma chip and hence the tcon board is bad since 16-18 went down instead of up?
                    Do the pictures match symptoms of bad gamma/tcon? Is the consensus to replace the tcon board (I don't have the skill to just change chip)?
                    Is there a way to rule out bad main board like originally thought?
                    Thanks!
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      In my experience, a faulty gamma chip will cause similar problems, but the entire picture will be slightly washed out. It's kinda hard to describe. Both times I've had the kind of image you show, a new main board fixed it.
                      Gamma Problem
                      https://www.badcaps.net/forum/attach...5&d=1387969634
                      Main Board Problem (not the best image)
                      https://www.badcaps.net/forum/attach...1&d=1365633902
                      Do you see how the colors are vivid in the second pic? Kinda like your pics.
                      Try diconnecting any sources from the set, power it on, and pull up the menu. If the menu looks fine with a source disconnected, it's not the gamma IC.
                        You have bad Gamma voltages. Similar picture to one of my repair.
                        http://s807.photobucket.com/user/bud...tml?sort=3&o=2
                        • T-Rex
                          • Feb 2014
                          • 14
                          Hmmm, I can see partly both. I see the problems in johnboys mainboard picture but I also definitely see the issues in budms picture.
                          The menus also do look off with no source - they are clear but color is kinda off in places like white are yellowed and the gradients are rough instead of smooth.
                          With the voltages off I guess it's safe to say AT LEAST the tcon needs to be replaced. I'd just hate to invest in tcon then still have to replace mainboard. I think at that point it may just warrant a new tv . I guess there is no way to test the mainboard to tell if it is also bad?
                          I assume shopjimmys is about the best place to get a tcon?
                          Thanks again...
                            Yep, agreed. Gamma curve is wrong. You will have to replace t-con or gamma chip. I doubt there is another fault.
                            The symptoms vary. Oversaturated colour and blown out whites are common. But sometimes, it can be as simple as the picture looking a little "off" -- colours not quite right, for example.
                            • T-Rex
                              • Feb 2014
                              • 14
                              Thanks guys. I ordered a tcon board 2 day from shopjimmys. I will report back Fri or Sat with results.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Sorry, for late answer, but I agree with Tom, bad Gamma chip.
                                I have just replaced one on a 46A630, but it was A15, not A19.
                                  BTW: forgot to add, the comparison for incorrect voltages is done across the whole curve, 1-20 or whatever, not over each block.
                                  • T-Rex
                                    • Feb 2014
                                    • 14
                                    Ok, so it was 13-15 that made this defective. If those descended from 6 - 4 volts then it would have been ok, but the jump up to 9 is what indicated its bad I guess. Funny how just a few volts can screw it up so bad.
                                    • T-Rex
                                      • Feb 2014
                                      • 14
                                      So I just wanted to update this and close it out. I installed the new tcon board and it fixed the problem completely, the picture is fine again. I just wanted to sincerely thank all of you who helped me troubleshoot this. The measurement of tcon voltages was a key item leading to a good Dx and fix. I am active on a large Home Automation forum where there is a similar level of help we all give and it's great to see that here as well where everyone chips in and helps the newbies and stuff, so thanks again for the assist.
                                        Nice to hear, enjoy the TV! It's a shame Samsung put a Chi Mei panel in this model, you'd expect better TBH.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
