JVC lt-32hg35e (Vestel) blinking LED
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Dear forum,
    I'm stuck with this old TV unit.
    PSU: 17PW04-1
    MB: 17MB62-1
    Symptoms:
    - Blue LED constantly blinking when connected to AC.
    - Only sigh of life is beeping when touching the capactive buttons on the front.
    Diagnostics so far:
    Checked the PSU output voltages:
    12V present
    5V present altought its only around 4.2V
    3V is present measured 3.4V.
    I check TP 202 which is for the short circuit protection: 0.606V on diode mode
    Since I met with some vestel models before with similiar symptoms I tried to flash U158 with different bin files.
    Sadly nothing changed, the led were blinking the same altough I'm not sure if the bins I tried were for these exact model.
    Does anyone have some tips or matching bin file for this unit?
    Thank you!
  • yokoono
    • Apr 2010
    • 481
    Try:
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      Originally posted by yokoono
      Try:
      Thank you,
      Flashed it on but sadly same results.
      Constantly blinking led.
      • yokoono
        • Apr 2010
        • 481
        It means that the problem is in nand or it is a hardware problem.​
        • Diah
          • Feb 2013
          • 6357
          could be led BL issue
          • unimatrix93
            • Oct 2021
            • 343
            • Magyarország
            I disconnected everything from the board, so only the PSU - MB - IR control panel is connected. Yet it still do the same.
            The PSU has a audbile chirping sound when connected to power.
            Maybe there is a problem on the PSU, every voltage are present on output but 5V is a bit low.
            • unimatrix93
              • Oct 2021
              • 343
              • Magyarország
              I found the schemtics of the power board and it looks like 24V is missing from PL205 (MB connector output) and 5V is missing on PL305 (Backlight inverter connector).
              • vinceroger69
                • Mar 2012
                • 6714
                you may have to jump some pins to get the missing voltages if your just bench testing the psu (im not sure which pins though)
                • unimatrix93
                  • Oct 2021
                  • 343
                  • Magyarország
                  What is wierd is that it looks like the 24v rail is disconneted on purpopse. Yet the schematics (both the PSU and the mainboard mentions it for the 32inch model)
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    can you take some pictures of the top and bottom sides of your psu and upload them thanks
                    • unimatrix93
                      • Oct 2021
                      • 343
                      • Magyarország
                      Sure,
                      • Diah
                        • Feb 2013
                        • 6357
                        seem you didn't understand my post#5 yours set just 32 take the screen out and there you will find the issue at LED BL
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          As diah ritely says yes remove screen and check the backlights (98% of my repairs lately have just been failed backlights)
                          • unimatrix93
                            • Oct 2021
                            • 343
                            • Magyarország
                            Sorry, I just removed the display and checked the backlight.
                            Backlight LEDs seems to working fine, however they light up in sections with my led tester.
                            This tv has edge backlight.
                            Maybe I should check with my bench PSU too?
                            • EazyBone
                              • Jun 2023
                              • 1316
                              • United states
                              Take picture of lights when lit. Sometimes to blinding to see one is dim or out when they close together on edgelit maybe
                              • Diah
                                • Feb 2013
                                • 6357
                                if the edge LED are double LED then there are zener diode build in.. if it get open or short PSU turn off but the tester light them on...
                                test each with DMM in diode mode
                                • unimatrix93
                                  • Oct 2021
                                  • 343
                                  • Magyarország
                                  I took out the backlight modules and tested each led diodes one-by-one with my PSU and with my DMM in diode mode. The LEDs are 6V and the voltage drop in diode mode were 0.775V so I guess they are fine.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Can you power each strip seperatly and see what each strip is using voltage and amps wise
                                    • unimatrix93
                                      • Oct 2021
                                      • 343
                                      • Magyarország
                                      My bench PSU only do 30V/5A maximum. However I can measure the voltage of the 3 segments with my tester.
                                      I can turn on the segments one by one by touching the black probe to the 3 test points on the board.
                                      Each segments uses 90-91V.
                                      I test the other 3 board in a minute.
                                      • unimatrix93
                                        • Oct 2021
                                        • 343
                                        • Magyarország
                                        All of them uses the same voltage.
                                        • unimatrix93
                                          Inexive (Vestel) TV constantly blinking after plugging in
                                          by unimatrix93
                                          Hello everyone, I have a constantly blinking Inexive LED TV.
                                          Display is: VES390UNVA-2D-N01
                                          Mainboard: 17MB97​
                                          PSU: 17IPS71
                                          The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
                                          03-26-2025, 08:36 AM
                                        • KevinWysocki
                                          Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
                                          by KevinWysocki
                                          Hi there,
                                          My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
                                          At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
                                          After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
                                          Flash upgrade didn't seem to work,...
                                          08-20-2023, 09:45 AM
                                        • lapfix
                                          Hp elitebook 820 G3 no display !
                                          by lapfix
                                          Hello friends.
                                          Hp elitebook 820 G3
                                          Motherboard model : 6050A2892301 no schematics or Brd available.
                                          Intel Core i5-6200U
                                          chipset = Skylake
                                          Ram = DDR4
                                          I'm using SANDS-6050A2725001-MB-A01 BoardView for help
                                          https://www.badcaps.net/forum/troubl...2725001-mb-a01
                                          Power on but no display with average consumption = 0.127 amp
                                          When i try to power off the lap responde to power button but...
                                          07-09-2025, 06:26 AM
                                        • France_53
                                          Vestel tv, how to flip the image?
                                          by France_53
                                          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                          05-12-2024, 05:22 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
