JVC lt-32hg35e (Vestel) blinking LED
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    #41
    Originally posted by Diah
    you are doing wrong..
    i wrote the cable of pin 7 should slide it out from the socket ( take it out ) the 1KR connected to the pin in the socket and other end to any pin of 17-19-21
    it look from yours photo you climp the 1KR to the end of the cable which it belong to pin 7..
    Progress:
    When I plug in the TV, the backlight flashes once, then blue led blinking. And when I unplug it from the socket the bl flashes again.
    • Diah
      • Feb 2013
      • 6357
      the cable of pin 7 out from the socket ?? if yes then keep it out and let the 1KR between pin 7 and 15 ... then try... if the behavior remain the same... you need to work on yours LED BL
      • unimatrix93
        • Oct 2021
        • 343
        • Magyarország
        #43
        Yes, the cable is out of the socket, floating in the air.
        I will try to solder the 1KR between pin 7 and 15 then report back on Monday.
        Thank you and have a nice weekend
        • unimatrix93
          • Oct 2021
          • 343
          • Magyarország
          #44
          It does the same.
          However I noticed that both 3.3VSTBY_1 and 5VSTBY has 4.20V. VCC_3v3_ON is 3.3v.
          Is this normal?
          • unimatrix93
            Inexive (Vestel) TV constantly blinking after plugging in
            by unimatrix93
            Hello everyone, I have a constantly blinking Inexive LED TV.
            Display is: VES390UNVA-2D-N01
            Mainboard: 17MB97​
            PSU: 17IPS71
            The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
            03-26-2025, 08:36 AM
          • KevinWysocki
            Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
            by KevinWysocki
            Hi there,
            My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
            At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
            After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
            Flash upgrade didn't seem to work,...
            08-20-2023, 09:45 AM
          • lapfix
            Hp elitebook 820 G3 no display !
            by lapfix
            Hello friends.
            Hp elitebook 820 G3
            Motherboard model : 6050A2892301 no schematics or Brd available.
            Intel Core i5-6200U
            chipset = Skylake
            Ram = DDR4
            I'm using SANDS-6050A2725001-MB-A01 BoardView for help
            https://www.badcaps.net/forum/troubl...2725001-mb-a01
            Power on but no display with average consumption = 0.127 amp
            When i try to power off the lap responde to power button but...
            07-09-2025, 06:26 AM
          • France_53
            Vestel tv, how to flip the image?
            by France_53
            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
            05-12-2024, 05:22 AM
          • YasaCh
            Sony kdl 40p5500 red light keeps blinking 3 times
            by YasaCh
            Hello...
            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
            i opened the back cover no sign of damage on the powery suply or motherboard
            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
            07-07-2025, 11:53 AM
