Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
  • KevinWysocki
    • Aug 2023
    • France
    Hi there,
    My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
    At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
    After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
    Flash upgrade didn't seem to work, LED keeps blinking. I have found a post on Hackaday that tolds CPU serial lines are available on SCART connector so I connected a TTL Serial/USB converter and obtained this boot/kernel trace :
    Code:
    loader eeprom dump succeed.
    ===>There is no MB82_DEVELOPER,will check MB82_AUTOTEST !!!
    ===>There is no MB82_AUTOTEST,will Boot Normally!!! Environment is root=/dev/mtdblock2 rootwait lpj=1814528 console=ttyMT0,115200n1 quiet mtdparts=mt53xx-nor:192k(loader),1216k(kernel),8M(root),64k(ro),576k(rw)
    hdr->ih_load = 0x8000
    hdr->ih_ep = 0x8040
    hdr->ih_size = 0x120c9c
    kernel_size = 0x3100000
    ====>copy kernel to dram normal_case :kernel_size=1182940
     NOR boot
    Do USB upgrade
    total mem size: 0x8000000, fbm addr:0x3bc0000, fbm size: 0x4440000
    USB upgrade stop
    Boot reason: A/C power on
    Offset:0x00000000
    Installed:0x11223345, 0x11223345
    dLastStandbyStatus = 0, dLastStandbyStatusOffset = 5, PDWNC_ReadWakeupReason() = 6
    PDWNC_SetT8032LEDBlinkOn 1___________________________
    Uncompressing Linux... done, booting the kernel.
    <mt53xx_nor_init>hank:V0.7.2m(protect 0 flash)...
    Flash Index: 0, MenuID: ef, DevID1: 40, DevID2: 17
    Setup flash information successful, support list index: 31
    Flash Index: 1, MenuID: ef, DevID1: 40, DevID2: 15
    Setup flash information successful, support list index: 29
    Disable write protect for flash #0 is illegal
    SQUASHFS error: xz_dec_run error, data probably corrupt
    [swapper(1)]squashfs_xz_uncompress .
    SQUASHFS error: squashfs_read_data failed to read block 0x7e237a
    SQUASHFS error: Unable to read metadata cache entry [7e237a]
    SQUASHFS error: Unable to read directory block [7e237a:16a5]
    Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
    [<c0024624>] (unwind_backtrace+0x0/0xe4) from [<c0186aec>] (panic+0x68/0xe4)
    [<c0186aec>] (panic+0x68/0xe4) from [<c0019500>] (init_post+0xac/0xd8)
    [<c0019500>] (init_post+0xac/0xd8) from [<c00089e8>] (kernel_init+0x124/0x16c)
    [<c00089e8>] (kernel_init+0x124/0x16c) from [<c001f71c>] (kernel_thread_exit+0x0/0x8)
    Whatever if USB key is connected or not, trace keep being the same, it seems that USB key isn't detected. It's a 64GB USB Key, partition is FAT32. I tried to reduce the partition size to 100MB, it didn't changed the result.
    Do you have any tips to upgrade flash content with a USB key ?
  • yokoono
    • Apr 2010
    • 517
    Re: Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
    Try recovery software. For stick.
    • KevinWysocki
      • Aug 2023
      • France
      Same serial trace, no USB device found.
      • baboom
        • Oct 2014
        • 5
        • Greece
        You can try with 2 or 4GB USB stick formatted as FAT32. If you can find one with LED indicator will be better.
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • kuba.cz
          Toshiba 32L2963DG / Vestel 17MB211S
          by kuba.cz
          I've got a Toshiba 32L2963DG (10124529) for repair and I'd like to share some info that I gathered so far. I don't usually repair TV's, so I'm exploring this new field. The TV randomly restarts while playing DVB-T2 or stops responding to remote control. It was connected to a wifi but internet apps were never used. Backlight LEDs were replaced in past by me. All voltages are stable, capacitors look fine.
          The main board is Vestel 17MB211S with Novatek SoC (ARMv7), TC58NVG2S0HTA00 NAND memory (4Gbit) and 25Q16JVSIQ SPI memory (16Mbit). I started the diagnosis by connecting...
          12-13-2025, 03:00 PM
