Phillips CRT 27PT543537A > screen flickers and then shuts off
  • jwblue
    • Feb 2014
    When turned on the screen flickers with different colors and after 10 seconds shuts off.
    What problem is the likely and what would it cost to repair?
    Re: Phillips CRT 27PT543537A > screen flickers and then shuts off
    Unlikely to be economical - I do not know how it is in the US but I regularly see 32 ~ 34" Sony Trinitron 1080i HDTV CRTs (XBR) given away for free - must be a couple every month...
    I would, with my little CRT knowledge, suggest high EHT causing xray detect fault (safety engaging.)
    • R_J
      • Jun 2012
      • 9628
      Check the elec. capacitor off the horz. drive transformer, its a low value (1-2uf) around 50v. also could be shorted diodes/output transistors in the vert. output circuit.
      My wayback machine is't working too good right now.
      • jwblue
        • Feb 2014
        I should clarify.
        What would it cost to have a television repairman fix it?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds like the 2005 RCA CRT that I posted about a while ago.
          Heard that it can be a bad solder joint and for the above mentioned CRT TV, it would shut off by itself after roughly 10 seconds, if I try to use it after it was turned off. (Seems that it has to warm up before it even possibly stays on.)
          That guy is long gone now! It was kicked out of the house then left in the snow, ice and rain before someone hauled it away.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • R_J
            • Jun 2012
            • 9628
            If I was repairing it in the shop it would be around $100.00 plus parts plus tax.
            even though its an old tv it still takes up time to repair.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              for the flyback probably. maybe t smash it? thats always a fun show
              Follow the white rabbit.
              • senz_90
                • Aug 2013
                • 328
                • Indonesia
                try R_J advice. also caps near vertical ic that has range same as he said and 50v. it look like your tv gone to protect mode because something wrong. many times just a failed caps about 50v. but who knows yours.. sometime there's another factor too.
                "There is no shortcut to be successful. No pain, no gain."
                Best Regards
                Rudi
                Thank You
                • popeye
                  • May 2011
                  • 155
                  You may be lucky try looking for dry joints on crt pcb.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • SarcasticOP
                    iPad Pro 12.9 (6th Gen) screen shuts off after unplugging device
                    by SarcasticOP
                    Greetings,
                    I have an iPad Pro 12.9" 6th gen tablet that had a screen replaced about 10 months ago at a repair shop and last week the screen went blank during use. The device was still on, notifications played sound for example. I have replaced the screen twice, both screens are working until I unplug it, at which point I can see that screen is on but is all black. If I press the power button, the backlight goes off, and when I press it again, the image appears for half a second and then the screen goes back to being black but on. This issue is not present at all when the iPad...
                    10-24-2024, 11:55 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • aaabddoo
                    Dell 3520 intel vga error when i instel vga intel driver The screen flickers need help pls
                    by aaabddoo
                    Dell Precision 3520​ intel vga error when Run the programl vga intel driver The screen flickers need help pls
                    Sorry for the language
                    06-15-2025, 02:42 PM
