Backlight halos 55PUS6754/12
  • sordids999
    • May 2013
    • 2161
    • uk
    Good evening
    Recently i have been asked to change the backlights on this set,but in the past ive done a set of this model and even with a brand new set of leds im still getting the halo effect on the screen once fitted.
    any ideas what's causing this ?
    Had a few philips recently been asked to do the backlights but try to steer clear from these philiips tvs
    thanks
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    I have had the halo effect issue on a panasonic tv (leds brought from ali express) i brought from a diffrent seller and no issues
    • EazyBone
      • Jun 2023
      • 1360
      • United states
      I have bought lights from Shop jimmy and they did this. I spoke to technical support and they said it's the led diffuser caps being the wrong size and they've seen this frequently .So the answer is get a different set of LEDs, probably different seller but also get a refund on your lights that you originally bought.
      • Rauni
        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
        by Rauni
        Hello, this is my first post on this forum, and my first attempted to repair a TV.
        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
        Read also that we should test what happens if we...
        10-01-2023, 12:06 AM
      • totof
        Samsung UE55JS9000 backlight issue
        by totof
        Hello.
        I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
        I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
        The result isn't perfect, but it still seems pretty good to me.
        10-05-2025, 08:27 AM
      • Bubbsy 2002
        Halo 5 inch and 6 inch White Integrated LED Recessed Downlight, destroyed by 180v power surger (Newfoundland Power Company).
        by Bubbsy 2002
        Hi all, I am on a 100% diagnostic spree and need some more assistance.
        I have looked at the board of this poor light and it appears I have an fuse/resistor combo.
        I have isolated what I believe are RV1 (destroyed by the surge) and you can see RV2, so I am assuming they are same or similar.
        Can you tell me what the name of the component, amperage/resistance, so I can order from DigiKey?
        And now I noticed the light went up $10 Canadian, to $46.
        Any help in this regard would be greatly appreciated....
        01-03-2024, 12:17 PM
      • alltvrepairs
        Philips 55pus6754/12 FZ3A Set Option value dilemma
        by alltvrepairs
        I need to change the main board for this set. I have a new identical board but for a smaller model 43PUS6704/12 FZ3A
        The picture is not good and remote seems not to work either.
        The Set Option on the rear of the TV says 042 as shown in pic.
        The Service manual lists this model but with another screen with a mentioned Option Code of 109. I assume that I need to use the one on the back of the TV.
        The problem I don't know how to tackle yet is the remote issue as not responding. Remote works on another Philips TV.
        03-16-2023, 06:06 AM
      • alltvrepairs
        Philips 55PUS6754/12 Backlight settings override TMP19.6E LA
        by alltvrepairs
        I would like to reduce the backlights for this set. There is no direct settings like in Samsung or LG etc. Probably in Option Codes in SDM.
        If not available I would like to ask if anyone managed to alter the circuit to reduce slightly the LED current. Uses PF7904S U8601
        Tks...
        01-24-2023, 04:59 AM
