Finlux 26FLD745T Tuner (?) trouble
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Finlux 26FLD745T Tuner (?) trouble
    http://www.bixreclamation.co.uk/TECH...2_p/p10064.htm mainboards arnt a bad price if postage is cheap and if it works in your country not sure what screen this ones for though.
    • 26fld745t
      • Jan 2014
      • 24
      • Finland
      Thanks for the tip, i´ll keep that in mind.
      I tried to replace the main board, but regional differences made the part unsuitable. Yas Tech U.K. was the supplier from where i ordered a replacement.
      It was stuck in some test mode, i guess, for the screen flashed slowly from red to green, blue etc.
      Furthermore, there was not a place for 2 x HDMI connector circuit board and some other differences so i gave up trying with the UK- originated main board.
      The original main av board was assembled in holland for markets of finland if i understood correctly.
      Now, the thing is that my client can use the TV with an DVB-T- set top box via SCART. I´ll just have to give up with this one, maybe both circuit boards of the TV are wasted in some way so replacing the main boards does not solve the issue.
      Thanks to all who participated and helped me on this one. Cheers!
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
      • spleenharvester
        Reverse engineering of 18650 4-channel tester
        by spleenharvester
        Hi friends
        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
        05-04-2025, 02:43 AM
      • mikey5791
        Help on car amplifier only one channel works
        by mikey5791
        Hi all forum members,
        Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
        My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
        08-06-2025, 10:36 PM
      • dicky96
        Hitachi V19B01922 Channel Tune problem
        by dicky96
        Hi Guys
        I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
        He also has an LG TV, so three screens in the bar
        I installed three Satlink ST-6503 DVB-T Modulators
        This model https://www.aliexpress.com/item/32916553905.html
        These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
        02-09-2023, 09:20 AM
      • dicky96
        American Audio VLP1500 Distorting on one channel
        by dicky96
        Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
        Protection and Clip LED are off
        There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
        I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
        The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
        07-13-2022, 05:25 AM
