Finlux 26FLD745T Tuner (?) trouble
  • 26fld745t
    • Jan 2014
    • 24
    • Finland
    Hello.
    I have this TV assembled in holland, problem is this:
    when i try to tune in channels, or monitor the TV signal strength at UHF channel 44,
    it (edit: the TV´s signal strength meter, horizontal bar) bounces from left to right, left to right repeatedly and random, from very good to no signal at all (image and audio freezes). At some moment it stays a couple of seconds in "good" or "very good" but then it suddenly collapses to no signal at all.
    At channel 32, 562MHz it bounces a little but it does not affect reception.
    At channel 58 the signal strength stays very good, also no problem.
    So, the tv is not useable when trying to receive terrestrial free-to-air mux-b of finland, channel 44 at 658 MHz.
    This far i have replaced the tuner part it self, but it did not solve the problem. Main a/v board part number is 17MB22-2
    There is also a conax reader circuit board which has 4 stickers that read:
    TDM PEV
    138TPV36
    26238816 TDM
    20333598 1300
    FINLX-PAN-325
    IDTV KART 20333598
    (BARCODE)
    20333598
    IDTV 225912
    xx xxxx xx ROHS
    (the rest of this sticker is messed up)
    The problem is not in the antenna and not in the antenna cable.
    I replaced one capacitor (Chang 3.3uF 50V) on the main board because tapping the cap with screwdriver made the picture freeze in every channel. Allthough this soldering did not resolve anything.
    Dear all, where should i look for fault now? I have googled some time but this Finlux model has not left many traces in internet.
    Best reguards,
    I.A.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Finlux 26FLD745T Tuner (?) trouble
    Did it ever work in Finland - was it bought in Finland or in Holland
    Does it work with other inputs - dvd/ scart/ PC
    Is there any sound?
      Check if 33V from PSU is stable, this is used to keep tuner tuned.
      • 26fld745t
        • Jan 2014
        • 24
        • Finland
        Thanks for the quick reply! Yes, it did work here. It is bought from finland abt. six maybe seven years ago, and is used in finland.
        Sound is ok, HDMI input is ok, SCART input is ok. All other TV channels are ok (tolerable) but the mentioned ch. 44 is a disaster.
        Bottom channels 562 mhz mux A,
        there is little bouncing in reception but it can be used.
        Middle channels 658 mhz mux B , a lot of bouncing, signal totally lost every few seconds
        Top channels 770 mhz mux C, 100% signal, no bouncing.
        Edit: i´ll check the PSU, thanks again
        br
        I.A.
        • 26fld745t
          • Jan 2014
          • 24
          • Finland
          At PL807, pin number 4 from left,
          of PSU there is 34.1V which is steady. Edit: that is all connectors disconnected. I´ll measure them next when everything is connected and live, tv turned on.
          Edit: 33.9V steady, tv turned on, channel 44, all connectors connected. Signal keeps disappearing and coming randomly.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Can you get that channel on another tv using the same aerial
            According to wiki which may be out of date channel 44 is the discovery channel
            and is not free to air?
            http://en.wikipedia.org/wiki/Televis...al_terrestrial
            • 26fld745t
              • Jan 2014
              • 24
              • Finland
              Works fine with my other tv:s and my measuring instruments. Here are frequencies and channels in finland´s dvb-t free to air network network:
              Here is the content of multiplexes in finland:
              http://www.digita.fi/kuluttajat/tv
              best reguards
              I.A.
                TV is configured for Finnish region? MENU 4 7 2 5 (in sequence, while powered on) for service menu then check if right DVB table is loaded.
                • 26fld745t
                  • Jan 2014
                  • 24
                  • Finland
                  Should be configured for this region. It has never been in any other region than here, from shop to the table. I tried to enter the menu several times, but failed.
                  Should the MENU button be kept pressed while entering the numbers, or should it be pressed all the time while entering 4 7 2 5 ?
                  a.k.a. "Never entered any TV´s service menu before... "
                    These Vestel can corrupt settings randomly...
                    Sometimes, you need to go to an analog TV channel (with snow), press 4,7,2,5 and then press MENU.
                    Other times (most new Vestel), you have to press MENU, wait for user menu to appear, then press 4,7,2,5.
                    • 26fld745t
                      • Jan 2014
                      • 24
                      • Finland
                      Tom66,
                      thanks for the advice. Analog channels -> Snow -> MENU -> 4725 made it this time. But, everything appeared to be ok. I performed reset, just for kicks but nothing changed, nor bad or good. Off topic, is there a pre-amp of somekind in the tuner?
                      What should i try next with this?
                        What options do you have in the service menu? Reset just goes back to defaults, if it thinks it is a Swedish TV it will reset back to Sweden. Note this is sometimes different from the user option. I had a Samsung 32" LED with poor Freeview (DVB-T) reception, and it was set to Netherlands region. And when I went into the user menu, it would only allow other Nordic regions to be selected. Changed it to the other Europe setting (IIRC, it had EUROPE-NORDIC and EUROPE-OTHER) and it worked first time. Reset didn't fix it, gave same options as before.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          You said you replaced the tuner - was the set exactly the same with the old one.
                          was the replacement a new one and exactly the same part number.
                          Check the centre pin is soldered correctly
                          • 26fld745t
                            • Jan 2014
                            • 24
                            • Finland
                            Exactly the same part number, new and soldered properly. A Thomson tuner that is. No datasheet/application note available at least via Google.
                            Scariest/funniest thing was that nothing changed by changing the tuner part.
                            I´ll go make some coffee and take a deeper look in the service menu..
                            • 26fld745t
                              • Jan 2014
                              • 24
                              • Finland
                              Factory Mode
                              Video Setup
                              Audio Setup
                              DRX
                              Options 1
                              Options 2
                              Options 3
                              Service Scan/Tuning Setup
                              External Source Settings
                              Picture Mode
                              Reset TV-set
                              26CMO_L01_DY
                              17MB22_FINLUX_IDTV_0.0.191
                              IDTV_v1.4.5
                              • 26fld745t
                                • Jan 2014
                                • 24
                                • Finland
                                Tuner Options- menu
                                Control Byte < +187 >
                                Low-Mid - LB < +48 >
                                Low-Mid - HB < +9 >
                                Mid-High - LB < +240 >
                                Mid-High - HB < +26 >
                                BSW1 < +1 >
                                BSW2 < +6 >
                                BSW3 < +12 >
                                • 26fld745t
                                  • Jan 2014
                                  • 24
                                  • Finland
                                  Search for L/L´ <yes>
                                  Pref. Search Standard <L/L´> (other possible settings for this are <m> and <bg,dk,i> )
                                  Station Ident <YES>
                                  ATS Delay Time (ms) <50>
                                  Color Kill Thr. <+70>
                                  Agc Thr. <+200>
                                  Ovm Thr <+160>
                                  Tuner Options (as in my previous post)
                                  Edit: found this
                                  http://wwwproject.org/schematics/fil...s%2017MB22.doc
                                  by googling the menu items. Almost everything in that .doc is identical with this Finlux i have.
                                  • 26fld745t
                                    • Jan 2014
                                    • 24
                                    • Finland
                                    The main a/v boards "CPU" cooling has been quite poor. A copper strip glued to the chip.. Downside of the board, under the chip, has turned color to brownish.
                                    Also the other circuit board, which holds the pay tv card reader slot... The big chip on that one has been quite hot, the text has faded. Those two circuit boards are obviously quite tightly "married" to each other, there´s that ribbon cable and a cable with 3 leads between them.
                                    Is there a way to check if the Conax card printed circuit board is in OK condition?
                                    • 26fld745t
                                      • Jan 2014
                                      • 24
                                      • Finland
                                      33V at PSU is 34V, and it is consumed on it´s way down to 32.8V at the tuner pin n:o 9, both steady. Dunno if this is within spec..
                                        That is fine
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • mikey5791
                                          Help on car amplifier only one channel works
                                          by mikey5791
                                          Hi all forum members,
                                          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                          08-06-2025, 10:36 PM
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
                                        • dicky96
                                          American Audio VLP1500 Distorting on one channel
                                          by dicky96
                                          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                                          Protection and Clip LED are off
                                          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                                          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                                          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                                          07-13-2022, 05:25 AM
