Panasonic TC-P55ST30 one led blink
  • smai
    • Dec 2013
    • 69
    TV used to start up fine then i had to unplug it for a while to get it to start now nothing and one blink
    i cant find the manual for this actual model but i did for TC-P55GT30 it shows one led blink means
    Panel information SOS
    LP1 Start SOS
    but doesnt really tell me which board to start with what does it mean ?
    any thoughts or have you seen this before ?
    Re: Panasonic TC-P55ST30 one led blink
    "A" board, usually.
    • Frank3y3
      • Jan 2014
      • 38
      So, did you had the time to take a look or test anything else concerning your 1 led blink ?
      • tw2005
        • Oct 2011
        • 6458
        LP1 Start SOS
        Here's something i do all the time, use the find function in the PDF reader and search LP1, you would find it located on the A-board which Tom has already mentioned.
        IC9300 LP1 which loads data from the SPI Flash IC9304. I have had a 1 blink on a 2010 board and by chance discovered a bad SPI Flash triggered the 1 blink.
        I guess either faulty flash or corrupted data in my case. Faulty IC9300 could do it too I expect.
        With my 2010 model i could isolate all the other boards and ribbons from the A and it would power up normal or in my case 1 blink remained which proved it was an A board issue.
        I don't think with these later ones that would prove anything as the troubleshooting guide says 3 fast blinks would occur.
        As for a manual,
        or check out the stickys, TV repair reference library under TOM66 who has a site with a collection of manuals.
        There's a 2012 ST50 guide here http://www.tgohome.com/ServiceManual...h=Submit+Query
        • smai
          • Dec 2013
          • 69
          no i have time today to open it up, i did find exact the service manual for this model, and thanks tom66 and tw2005 for your input guys
          • smai
            • Dec 2013
            • 69
            soo whats the difference between all these boards ? mine is TNPH0912 with AB as the suffix? can i replace it with the same board but with AF as the suffix ?
            • smai
              • Dec 2013
              • 69
              okay i figured out i have AD, but does this mean i can switch it with any board as long as i change the resistors to match AD? does anyone know what these resistors are actually doing from model to model ?
              • tw2005
                • Oct 2011
                • 6458
                No. Don't think those jumpers do anything. The one you mention is 65", eeprom/flash data will be different for the size
                • smai
                  • Dec 2013
                  • 69
                  got a new A board plugged it in, now 7 blinks points to the SU SD board
                  did the jumper test, powered on, no blinks so that clears the SC board
                  i cant seem to find a way diagnosis just the su or just sd board any tips?
                  and are the SD/SU boards interchangeable between models or different versions of the same tv i need TNPA5340 but found TNPA5340AK they have different pany part numbers
                  and a final thought the A board i got is damaged (see pics) you think it will be okay or should i have the seller replace/return it (and im pretty sure i need an A board i put the old one back in and tried the jumper trick from earlier and still only 1 blink )
                  • smai
                    • Dec 2013
                    • 69
                    opps double post by accident
                    • tw2005
                      • Oct 2011
                      • 6458
                      Try slide 71 on since you've already got a clear startup with the SC50 jump.
                      You're certainly going to have to grab the HDMI body well if you attempt to straighten that tab. Could always try a partial refund? A boards can be hard to find so you probably don't have a lot of leverage.
                      • smai
                        • Dec 2013
                        • 69
                        sweet thanks, i dont have this service manual
                        im more worried about the other photo with the chip knocked off the part
                        • tw2005
                          • Oct 2011
                          • 6458
                          Oh, ok did not check that one. Doubt that will be a major issue. It's just an inductor, probably not too hard to track one down. I'd have a go at getting a price reduction though. If using Paypal, you have evidence of it not as described.
                          How rare are the boards though?
                          • smai
                            • Dec 2013
                            • 69
                            this one with the suffix AD wasnt the easiest to find but i think he has another and i have seen a few others on the bay site ill see if he want to toss some money back my way
                            so once i started testing the boards trying to narrow down which baord needed to be replaced, the TV just started working im guessing a reseat of the ribbon did it
                            but now i am getting a buzzing from the SS but ONLY when there is video or something being displayed if the screen is BLACK i dont hear it or its very low, there might alos be buzzing coming from the power board and on the SS, the heat sink that has a few regulators bolted to it is HOT i can feel it radiating im guessing that is somewhat normal, but how to i proceed on stopping the buzzing ?
                            i can take a video if need be
                            • tw2005
                              • Oct 2011
                              • 6458
                              make sure the bolts are secure, otherwise can't say i've struck a Pana with buzzing boards except when I had a loose SC.
                              • smai
                                • Dec 2013
                                • 69
                                they offered 15 dollars back and 90 day warranty or just a 6 month warranty what do you think ?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Comes down to whether $15 is life changing or the wty, provided they're still around and keep their word.
                                  As a percentage of the original purchase ?
                                  Bottom line is you need one, not much difference between 3 & 6 months, you'd be unlucky if this went again.
                                  Can go into the service mode and see how many hours it's clocked up.
                                  • cloo
                                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                    by cloo
                                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                    After doing a factory reset this problem was gone and the picture was back to...
                                    01-06-2025, 06:02 AM
                                  • Vebririon
                                    panasonic TX-P50V10E 6 blink led problem
                                    by Vebririon
                                    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                    05-17-2025, 10:16 AM
                                  • nervx
                                    Panasonic TH-42PZ800 8-blink error mystery
                                    by nervx
                                    Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                    Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                    04-08-2022, 05:19 AM
                                  • SentraDude
                                    (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                    by SentraDude
                                    Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                    I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                    Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                    04-04-2023, 04:24 PM
                                  • BigPete
                                    Panasonic Heatpump Dryer Repair
                                    by BigPete
                                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                    Unfortunately the whole machine has to come apart to fix it.
                                    I have...
                                    11-01-2025, 06:40 PM
