fu tv fl32050 stuck on logo
  • wolf1976
    • Oct 2023
    • 104
    • Ελλάδα
    sir do you have read this chip with ch341a or will i need an other programmer ?
    thanks on advance
    • lotas
      • Jan 2016
      • 4468
      • Russia
      thanks on advance
      Yes, it’s not I who should count it, but you, you have a TV, I gave an example of which chip you need to select in the programmer program. The rest is up to you!
      • wolf1976
        • Oct 2023
        • 104
        • Ελλάδα
        ok i understood just i wanted to be sure this programmer ch341a was suitable for this particular component before i desold it from pcb
        • wolf1976
          • Oct 2023
          • 104
          • Ελλάδα
          hi again As for the reading I did from flash memory there is a confusion in it the first time I read file 1 and all the next 5 times I read file 2 the strange thing is that when I did verify ic it always gave me an error but also with another spi that I tried the same did not make it sticky but I had put it on a special base for SPI that unlocks and locks
          Finally I uploaded a file from an akai mainboard but it wouldn't let me erase and blank so I passed it over now I stuck it and it's permanently standby it doesn't even get a command
          • lotas
            • Jan 2016
            • 4468
            • Russia
            What you got was not a dump, but complete garbage, as you read? Did you solder the flash through a clothespin or through an adapter on the programmer? Were the legs on the flash washed of flux with alcohol (maybe there was a bad contact)?
            • wolf1976
              • Oct 2023
              • 104
              • Ελλάδα
              #26
              I understood and I did both the stupidity and I passed another program from Akai TV with a similar chassis on top overwrite and now the TV is only on standby does not take any command so it is useless since I completely destroyed its first even defective file right?
              • lotas
                • Jan 2016
                • 4468
                • Russia
                #27
                These two dumps are completely destroyed and cannot be restored, here is a working dump for your hardware (main + panel), try it!
                • wolf1976
                  • Oct 2023
                  • 104
                  • Ελλάδα
                  #28
                  thanks a lot sir you are very helpful
                  just i want to ask you when i tried to do blank or erase on old flash ic it doesnt allo me and has a message writing register addresss protect
                  only when i did write it completes the proccess with success like overwrite i hope to understand
                  so on your opinion must i buy a new flash or is there other way ?
                  • lotas
                    • Jan 2016
                    • 4468
                    • Russia
                    #29
                    Before erasing, try unchecking all the checkboxes in the status register and executing “write”. If you can't make it your programmer, then install a new 25Q64 (from Winbond)​
                    • wolf1976
                      • Oct 2023
                      • 104
                      • Ελλάδα
                      #30
                      thanks a lot one more time sir
                      just if i dont have winbond like to advice me i will order from aliexpress when i test it i will inform you
                      • wolf1976
                        • Oct 2023
                        • 104
                        • Ελλάδα
                        #31
                        sir i wanted to ask because i want to order winbond 25q64 as you tell me
                        what exactly
                        25Q64FVSIG ? 25Q64FWSIG ? or 25Q64BVSIG? is more suitable for my case ?
                        • lotas
                          • Jan 2016
                          • 4468
                          • Russia
                          #32
                          25Q64FVSIG, 25Q64BVSIG
                          • wolf1976
                            • Oct 2023
                            • 104
                            • Ελλάδα
                            #33
                            thanks
                            • wolf1976
                              • Oct 2023
                              • 104
                              • Ελλάδα
                              #34
                              sir i used your file but unfortunately for me its not working
                              its going on standbybut it doesnt turn on either from button or from remote control
                              • wolf1976
                                • Oct 2023
                                • 104
                                • Ελλάδα
                                #35
                                i used winbond 25q64hv i did and confirm after writre all are success
                                probably the file is not compatible with mine tv do you have other file ?
                                • lotas
                                  • Jan 2016
                                  • 4468
                                  • Russia
                                  #36
                                  Is there anything else missing on your TV? During dismantling and installing the chip, nothing was damaged, were there any nearby components?
                                  • lotas
                                    • Jan 2016
                                    • 4468
                                    • Russia
                                    #37
                                    winbond 25q64hv - Does such a chip exist?
                                    • wolf1976
                                      • Oct 2023
                                      • 104
                                      • Ελλάδα
                                      #38
                                      sorry 25Q64FV
                                      • lotas
                                        • Jan 2016
                                        • 4468
                                        • Russia
                                        #39
                                        You can post a high-quality photo with this chip, I want to see how things are in this place.
                                        • wolf1976
                                          • Oct 2023
                                          • 104
                                          • Ελλάδα
                                          #40
                                          i understood sir lotas
                                          By tomorrow noon I will have sent it
                                          • x_orange90_x
                                            Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                            by x_orange90_x
                                            I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                            12-28-2023, 06:26 AM
                                          • justice171
                                            JVC LT-50N795 Stuck on Wisdom Share Logo
                                            by justice171
                                            I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                            It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                            Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                            Thanks in advance!
                                            11-04-2024, 02:55 AM
                                          • mr.Data
                                            Macbook A1990 stuck on logo
                                            by mr.Data
                                            This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                            All the normal methods of resetting this Macbook have been tried but do not work.
                                            I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                            Any help would be greatly appriciated....
                                            04-18-2024, 11:51 PM
                                          • platinumsteel
                                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                            by platinumsteel
                                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                            03-18-2024, 05:16 PM
                                          • digtalhd
                                            Dell Inspiron 7490 Stuck on Dell Logo
                                            by digtalhd
                                            Hi!
                                            Anyone hepl me! My laptop stuck Dell logo after I clear ME.
                                            Dell Inspiron 7490
                                            S/N: 28760285127
                                            LA-H451P Rev: 1.0
                                            Thank!...
                                            11-13-2024, 10:17 PM
