Hisense HE43A6100UTWS Panel problems
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Panel shows two good half pictures when alternatively plugged in but poor/ distorted picture when both sides of panel are plugged in. Is this a panel or drive fault?
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Is the right side upright or upside down?
    • Diah
      • Feb 2013
      • 6581
      half buffer issue caused by all in one boards (MB) try first with firmware to downgrade.. if not solved.. replace all in one boards.
      • Grunder
        • Jan 2016
        • 323
        • south africa
        No set was upside down so as not to put pressure on the knob at the bottom. Thanks
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Thanks Diah, Now that I know it's the main board I can see if the repair is viable as it looks like its abit old & not smart. A local supplier has one for 1100 zar. Will look see if I can do the firmware downgrade (download & upgrade?) first though.
          edit: sorry it is smart so might be worth it. Tx
          • Diah
            • Feb 2013
            • 6581
            go to Hisense FTP server and download early firmware for yours set... the end format of yours set should be .bin
            Password: Hisense1234
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Thanks Diah, most appreciated, will try and get back
              • Grunder
                • Jan 2016
                • 323
                • south africa
                Hi Diah, Ibe tried the link for Hisense ftp server but keep getting "There were input errors, please try again later. I don't know if this is because I have an old Galaxy A5 phone (I get denied access to various sites saying the my device is not suitable/ old). I went to the official site and tried the support route but also came up blank. Up until recently Hisense factory (assembly plant) in our country had a fair spares supply chain to the public but lately the phones either drop your call or don't answer. A larger repair company in another province/ state have access to the board and at a last attempt will just replace the main board as opposed to downgradin to a an earlier version as you suggested. I thought the bin file might be resident on Badcaps but not really sure on how to find the file. I referenced the panel number but it doesn't come up? So will attempt board replacement. Thanks for all. Mike
                • vinceroger69
                  • Mar 2012
                  • 6714
                  i get the same error code
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4540
                    • Italy - Milan
                    Hi, post a picture or more of the back side view of boards.. my guess is bad tcon board.. bye...
                    • Diah
                      • Feb 2013
                      • 6581
                      server working with out any issue .. i just logged in.. n used firefox desktop PC
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4540
                        • Italy - Milan
                        ..more than TCON i suspect bad panel stripe boards..
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          yes working fine for me now im on laptop.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4540
                            • Italy - Milan
                            I really don't know how one can say this could be a software issue.. waste of time as usual..
                            • Grunder
                              • Jan 2016
                              • 323
                              • south africa
                              Thanks Diah, Davi and Vincent. Sorry slow response, eventually got tar file. Funny thing is when I switched the TV on it had a perfect picture...until it started playing up again.
                              I beginning to think it's a poor connection somewhere? Can software be intermittent? Long story short, I wasnt able to get the TV to digest the tar file, mp pc said the tar file was there, but TV couldn't find it.
                              I've done a factory reset, will this "repair" the firmware?
                              The TV is on my workbench and if the fault comes up again I will check the print on the tcon as Davi suggested.
                              • Grunder
                                • Jan 2016
                                • 323
                                • south africa
                                Pc says it's on the usb, TV says it isn't, but problem seems to solved for the meantime, thanks all
                                • Diah
                                  • Feb 2013
                                  • 6581
                                  half buffer issue are caused when firmware cliche .. now it show correct because USB view in other resolution..
                                  the .tar file you have now should extract with 7zip to have the end format file
                                  • Grunder
                                    • Jan 2016
                                    • 323
                                    • south africa
                                    Thanks Diah, I will try to extract bin from tar. Have been using my phone to work with and need to get my pc online to do this properly.
                                    The TV freakishly ran for about 3 hrs last night and I was able to watch utube flawlessly then it flunked out again. I turned t upside down and back and that appeared to work for awhile, then flunks out. All kinds of twisting and contortion from there didn't help. It appear that when I was flipping through the menu that certain images woukd have a different effect on the screen( a few very bars to blank screen) so maybe like you suggest different resolutions would have different effect on the buffer.
                                    I would really like to do the binfile rewrite but the repair is now 2 weeks on my bench. I've requested am order for a new main board and looks like I might just replace the board to satisfy my customer. Will let know final outcome. Thanks, Mike
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4540
                                      • Italy - Milan
                                      Oh my god.. not even the ABC of the LCD screens here! The LCD screen outputs always at the same resolution, are the inputs on the main board that can vary and main board SoC scale them with scaler function..!! The fact you vary the good and the bad output simply disconnecting the LCD flats tells you clearly that the fault is in the screen (tcon comprised)..
                                      • Grunder
                                        • Jan 2016
                                        • 323
                                        • south africa
                                        Hi, Sorry for the discourse created. This particular symptom definitely seems to be a hardware problem as on switch on this morning it played perfectly until I wobbled the TV and the symptom appeared. (Video clip can be supplied) Wether it's the panel or the main board I can't say but I can't take the chance with the expense involved. The TV will be returned unrepaired unfortunately and put down as panel faulty/ uneconomical to repair. Thanks for all the input and hopefully differences can be put aside. Regards, Mike
                                        • mecha1166
                                          Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                                          by mecha1166
                                          Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                                          06-13-2024, 02:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
