Panasonic TC-P50ST50 5" vertical black bar
  • stupidPanny
    • Jan 2014
    • 11
    My TV likes to intermittently flash this vertical line
    I read the troubleshooting guide from here, and my best guess is the "Vertical Line-Same width as FPC" even though the blacked out area is larger than what they say it should be.
    I took off the back, wiggled around the cables and reclamped them which seemed to make the problem better. Prior, the black bar would show 20%-30% of the time, after my calibrated wiggle they disappeared for a couple weeks. Now, they are back at 70%.
    Any suggestions on what to try next?
    Re: Panasonic TC-P50ST50 5" vertical black bar
    Just out of warranty I guess? Newish set.
    I'd check all connectors along the C board, and check ribbon cable is fully seated.
    • stupidPanny
      • Jan 2014
      • 11
      Tom66, thanks for the reply. Unfortunately the warranty on these is only 1 year, so I'm well out by now.
      By ribbons, I assume you mean those that appear to wrap around to the front, on the left side of this picture?
      Which connectors should I be looking at?
        Along the bottom left side of the "A" board (which has all the video inputs on it like HDMI) there are two fat ribbons and one smaller one. I'd see that both fat ones are seated correctly on both ends. Only make changes to these with power to the set disconnected from the wall.
        • stupidPanny
          • Jan 2014
          • 11
          Would you suggest that I just adjust those ribbons to start with? Also, how dangerous is it to turn the TV back on without replacing the back casing?
            Yes, those ribbons would be my first check point.
            You can operate the TV without the case on, just do not touch any part as it could present an electrocution hazard. Plasma display use 200 volts for panel sustain and 350 volts for panel initialise, so that presents a shock hazard...
            • stupidPanny
              • Jan 2014
              • 11
              Tried it, and unfortunately a no-go. What's the next idea?
                Try tapping lightly around the connectors on the C board or A board with an insulated screwdriver handle - any difference to the picture?
                • stupidPanny
                  • Jan 2014
                  • 11
                  Nothing, but I can't easily get to the connectors on the bottom from the C1/2/3 buffer boards as they wrap around into the screen.
                  Noticed that the 3 buffer boards have 15 ribbons, which if spaced equally on the screen they would each cover ~2.9". Since the black bar is roughly 9", that might mean 3 consecutive areas are not displaying correctly. Add in that the area that is not showing is ~14.25" from the edge, if everything aligns it would mean the rightmost 3 ribbons from C2 are aligned with the problem area.
                    Yes, you can try reseating those now. However, I suspect that your problem is with either the C(1,2,3) board or A board. Not sure which.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Give the mirror option a go in service mode
                      "6.2. Option - Mirror
                      Picture can be reversed left and right or up and down.
                      00 : Default (Normal picture is displayed)
                      01 : Picture is reversed left and right.
                      02 : Picture is reversed up and down.
                      If the defective symptom (e.g. Vertical bar or Horizontal bar) is moved by selection of this mirror, the possible cause is in
                      A-board"
                        Good idea. Didn't think of that.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Almost worth a gamble at $30 for a full set of C buffers.
                          PM sent with links.
                          Has all parts for yours it appears and seriously cheap!
                          Hope it's not the panel. If me I'd grab a full set of spares looking at these prices if the panel ends up good. About $220 for a full suite.
                          Worst case if the panel is shot sell the parts or park it and hope another 50ST50 surfaces with a good panel and blown SC,A etc for sale.
                          • stupidPanny
                            • Jan 2014
                            • 11
                            Okay, made it into the service mode but how do I get a picture to display? It won't let me save the reversed setting, and the background is black so I can't tell if there is a "black bar"
                              It should be on whatever input last. You can turn it off first, set an input up (e.g. HDMI or onboard tuner) then turn it on again with that input still connected, it will boot up into service mode like that. At least, that is how it has worked on the older sets, I do not think they have changed it.
                              • stupidPanny
                                • Jan 2014
                                • 11
                                Ah, that worked. I think the only input it doesn't work for is USB, which is what I was using.
                                The black bar remained in place, so I have to assume this is likely the C boards?
                                Also, does the fact that it is only flashes up indicate something else? The flashing is tempermental. It seems to be rare when the TV starts up, then get progressively worse for a few hours. If you let the TV on for 12+ hours, it becomes more rare.
                                  One thing you could try doing is getting a hairdryer out and start heating up parts. As the set warms up something is expanding and losing contact, or otherwise failing to work, and heat will make this happen quicker. Just be sure not to get it too hot, about 30 seconds in an area should be enough to narrow down a particular part.
                                  The fact that the bar doesn't move doesn't rule out all possible A board faults. If it did move, it would be a certain A board fault.
                                  • stupidPanny
                                    • Jan 2014
                                    • 11
                                    Alright, finally had a chance to try this out and wasn't able to really achieve much. The bar is fairly hard to predict, so i couldn't really tell when I was accomplishing anything.
                                    Any other suggestions, or is it worth replacing both A and C boards at this point?
                                    • Frank3y3
                                      • Jan 2014
                                      • 38
                                      God Damn, i'm a begin to suspect Tom and Tw works as FBI Panasonic technicians. These guys are very helpful at giving inputs where to go, what to inspect and what to try. Thumbs up !
                                        Little does anyone know, I'm actually working for Panasonic trying to stop people buying Samsung and LG panels as replacements .
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
                                        • canadaboy25
                                          Panasonic TH-50PX75U black vertical bar and colored lines
                                          by canadaboy25
                                          Hey guys,
                                          I had a previous thread about this TV here: https://www.badcaps.net/forum/showthread.php?t=79192
                                          My problem was the top half of the TV had went out and the problem ended up being on the SU board.
                                          That problem is now fixed and I am left with a different problem. There is a roughly 2" vertical black bar on the left side of the display and a single pixel wide red and green stripe on the right side of the display.
                                          I have tried reseating the ribbon cables to the panel without any results. I do not think the TV had this problem before...
                                          01-16-2021, 03:07 AM
                                        • Rescogitans
                                          Panasonic cf 20 will no longer boot-only black screen
                                          by Rescogitans
                                          Hello all. Only my second post.
                                          I have a panasonic CF-20C5142VM which was booting to bios with no issues. I needed to add an ssd that was not initially being recognized by the bios. Found a link that suggested that I disable uefi mode and clear keys then to reboot to allow bios to now see New ssd. After restarting, screen is entirely black with no image. Found another post that suggested unplugging bios battery because some remnants of the bios may still exist in other parts of board but did not fix issue-screen is still black.
                                          Anyone run across something like this before?...
                                          12-07-2022, 12:04 PM
                                        • Ancient1
                                          Strange LG TV issue : Image vertical lines in black screen
                                          by Ancient1
                                          Hi
                                          Asking for a friend.
                                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                          but here its the opposite !
                                          TV has new T-con = same issue
                                          A missing panel voltage would have global effect
                                          So , what should one do ? how can I find where the fault is ?
                                          Thanks !...
                                          02-05-2025, 03:37 PM
                                        • evanroheff21
                                          Panasonic TC-P65ST50 plasma vertical black section repairable?
                                          by evanroheff21
                                          I've acquired a 65" Panasonic TC-P65ST50 for free from someone while purchasing another TV for repair from them. I've repaired ~10 LCD TVs over the years with decent success, and I enjoy doing it. However this is my first attempt at a plasma, and I'm treading carefully.
                                          The TV when I got it would power up, however the left ~5 inches of the display was entirely black, basically like a letterbox image would appear. I disassembled, looked up some info, and determined that it was likely either dirty/loose connectors between the panel and the C buffer boards...
                                          03-10-2020, 10:15 PM
