Panasonic TC-P50ST50 5" vertical black bar
Re: Panasonic TC-P50ST50 5" vertical black bar
So what step would you recommend next? And I haven't said it enough, thanks for all the helpComment
The million dollar question.
My gut tells me it's probably not A board. If i was working on this, double check all ribbons are seated correctly including the ones going to the C board in question. I'd inspect the contacts of the white ribbons in case there was corrosion or poor contact. Possibly with something non conductive flex the c board or apply pressure to the tiny 20 pin octal buffer ICs on that board, inspect them maybe for dud solder joints (magnifier), maybe warm them up or try freeze spray on them but not while it's running.
Try replacing the c board/s but for all I know it could be the panel but you said it was intermittently working at some stage. I would have expected failing ICs on the panel ribbons would be a more gradual decay of the picture with noisey lines not complete loss of data in one hit and it's not just one ribbon but 2 or 3 by what you have described.
For me that poses the question of the likelihood of all of those dying at the same time. I could understand that if a portion of the Octal buffer failed assuming that has something to do with the data sent to those ribbbons.
It's not an area of knowledge I posess but for what it's worth that's what i'm thinking.
Given the worth of the TV I would spend $30 for some C boards at the chance the panel is good, I could not justify an A board but I sent you a link for some real cheap bits.
at the end of the day you're not having to pay a workshop to diagnose this so you're already miles ahead $$ wise.
I know if this was mine in Australia I'd be challenging Panasonic to fix it out of wty if I had receipts and was the original purchaser.
Someone advanced with an oscilloscope may be able to prove whether the signals are actually being delivered to the panel ribbons. If they were mising at least it may be possible to trace back to where they disappear.Last edited by tw2005; 01-31-2014, 12:27 AM.Comment
Well I tried a set of replacement C boards. The problem was far worse (more sections not displaying), so I had the company send me another set with basically the same results.
Suggestions?Comment
by FirentiosiThanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
The issues are as follows: the...2 Photos -
by canadaboy25Hey guys,
I had a previous thread about this TV here: https://www.badcaps.net/forum/showthread.php?t=79192
My problem was the top half of the TV had went out and the problem ended up being on the SU board.
That problem is now fixed and I am left with a different problem. There is a roughly 2" vertical black bar on the left side of the display and a single pixel wide red and green stripe on the right side of the display.
I have tried reseating the ribbon cables to the panel without any results. I do not think the TV had this problem before... -
by RescogitansHello all. Only my second post.
I have a panasonic CF-20C5142VM which was booting to bios with no issues. I needed to add an ssd that was not initially being recognized by the bios. Found a link that suggested that I disable uefi mode and clear keys then to reboot to allow bios to now see New ssd. After restarting, screen is entirely black with no image. Found another post that suggested unplugging bios battery because some remnants of the bios may still exist in other parts of board but did not fix issue-screen is still black.
Anyone run across something like this before?... -
by Ancient1Hi
Asking for a friend.
I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
but here its the opposite !
TV has new T-con = same issue
A missing panel voltage would have global effect
So , what should one do ? how can I find where the fault is ?
Thanks !... -
by evanroheff21Hello,
I've acquired a 65" Panasonic TC-P65ST50 for free from someone while purchasing another TV for repair from them. I've repaired ~10 LCD TVs over the years with decent success, and I enjoy doing it. However this is my first attempt at a plasma, and I'm treading carefully.
The TV when I got it would power up, however the left ~5 inches of the display was entirely black, basically like a letterbox image would appear. I disassembled, looked up some info, and determined that it was likely either dirty/loose connectors between the panel and the C buffer boards... - Loading...
