Panasonic TH-50PX75U top half of screen blank
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys, I was given a Panasonic plasma because the top half of the screen was black but the bottom half was still working normally. Sometimes the top half would flicker on and off. I tried reseating all the ribbons and cables thinking it was a loose connection but it made no difference. After I fooled around with it for a while it was working most of the time with only the odd flickering on the top half. There was no real correlation between my tests and it starting to work. I set it up and started using it and it was perfectly fine 98% of the time. I used it like this for a couple months with no real issue. However, the TV has been left off for 4 months and now when I turn it on the top half it always black. Percussive maintenance has no effect.
    I found this thread where the solution ended up being a replacement upper buffer board: https://www.badcaps.net/forum/showthread.php?t=27128 However, in that thread it was stated that it is very easy to get a bad replacement board due to parts being pulled from cracked TV's. For this reason I would rather repair my board than chance buying a bad replacement. This should also be cheaper than buying a whole board.
    I recently repaired a Hitachi plasma with help from you guys where the issue was a shorted buffer ic on the upper buffer board: https://www.badcaps.net/forum/showthread.php?t=75627 I did the same diode mode test on this board as I did on the Hitachi and found no shorted buffers. I suppose this makes sense as it is not bringing down the whole display like on the Hitachi.
    So my question is, what else could the fault be? The only components on the buffer board are the buffers themselves and a few resistors/diodes/capacitors. Can the buffers just stop working even though they test fine in diode mode? I also can't see the part number of the buffers as they have a heatsink glued on top which I would rather not pry off if the chip is in fact fine.
    Any ideas on what to look for next are appreciated.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • FrozenHaxor
    • Jun 2015
    • 266
    • Poland
    Re: Panasonic TH-50PX75U top half of screen blank
    Most likely your problem are the high voltage driver ICs on the board responsible for supplying the side that has a problem on it. Try buying a board from scrapped TV. Most of those are out of circulation at this point due to high failure rate and general age so your options are rather limited. I know that at least in my country it was possible to still order new original parts from Panasonic but the cost was outrageous and my customer wanted me to scrap the TV.
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      That was my suspicion but they all seem to test the same so it is difficult to narrow down which one is causing the board to fail. I guess I will just have to replace them all.
      Buying a board from a bad TV is what I was trying to avoid due to the reasons listed earlier and also like you said, because they are all old by now and few left.
      I suppose I will pry off one of the heatsinks and see what number the chips are. This tv is not worth spending much money on so expensive repair options are not feasible.
      canadaboy25
      • FrozenHaxor
        • Jun 2015
        • 266
        • Poland
        Last time I worked on one of those the high voltage drivers had a nasty glue all around them bonding to PCB making it really difficult to replace. Perhaps you could try local heat from a hot air station on given chips and then look for a change on the screen, it just might work to narrow the rotten apple down. From experience heat works better than freeze spray. Bring it almost to soldering temperature but not too high. I'd remove the heatsink before heating though.
        • canadaboy25
          What is normal?
          • May 2013
          • 509
          Tried heating each chip but no results. Guess I'll have to pry one heatsink off and see if I can tell what the chip number is.
          canadaboy25
          • R_J
            • Jun 2012
            • 9624
            The buffer ic's should be AN16076A-VT, most of the drive data lines and voltages are common to both the SU & SD boards, it is very likely it is just the SU board, there are a number of resistors that you could check IE: R6902,2,4 (22Ω) or R6925,6 (0Ω)
            When you checked the buffer board with your meter you were checking the buffer outputs, The whole top half is black so it is likely the buffer inputs have the problem, a shorted clock or data line on one ic would kill the signal to all of the upper ic's
            • canadaboy25
              What is normal?
              • May 2013
              • 509
              Well I spent some time probing the input signals to the SU and SD boards to no real result. On the connector going from the SC to SU board I get a clock on CLK and some data on OC1 and OC2. It looks to be the same on both the SU and SD boards. However, the SI pin which appears to be serial in and is then daisy chained through all the buffer chips, has what appears to be random pulses on it. The strange thing is there is no signal at all on the SI pin for SD which is the board that is actually working. I also have no idea what OC1 and OC2 actually stand for.
              In order to do these measurements relative to the floating ground I had to float my scope using a ups. Yes, I know this is not recommended but I'm not going out to buy a $1000+ differential probe to fix an old plasma. I also don't think that having the ground pin on my scope live while probing the tv is any more dangerous than actually probing a running plasma tv.
              None of these observations matter though because during my testing I forgot to unplug the ups from the wall to float the scope and the ground pin on my probe touched a large resistor on the VSUS rail which killed the TV and now I get 10 blinks. Amateur mistake but hindsight is 20/20. None of the fuses seem to be blown so I'm not sure where to look for what I blew. If it's not a simple fix to undo my mistake then I will probably have to admit defeat on this one.
              canadaboy25
              • canadaboy25
                What is normal?
                • May 2013
                • 509
                Well I went to start troubleshooting what I blew up and the tv powered up just like it did before I shorted the VSUS rail. I must've popped some resetable fuse or something that just took a while to cool off. So basically I'm back to troubleshooting the original problem.
                canadaboy25
                • canadaboy25
                  What is normal?
                  • May 2013
                  • 509
                  I finally had time to get back to this TV.
                  Just for the sake of anyone else who might encounter this thread by googling for the same problem, I figured I would post the solution.
                  I did some diode mode tests on the SU and SD board data connectors. All values were basically the same except for one pin. I then traced the problem on that data line down to a bad 0 ohm link R6925 on the SU board. Replaced the link and the top half of the TV is working again.
                  Reading back through this thread I can see that it was suggested to me to test this component but I seemed to have been distracted by accidentally shorting something while testing.
                  Oh well, I got there in the end.
                  canadaboy25
                  • Chrissygizmo
                    Panasonic TX-48CX350B backlights but white screen , blank screen
                    by Chrissygizmo
                    Hi all, I’ve got a problem I hope someone can help me fixi.
                    I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                    01-11-2025, 03:18 PM
                  • armoured_smiler
                    Panasonic Tx-40cx400b top left half screen not displaying correct
                    by armoured_smiler
                    Trying to work out if this is TFT problem or TCon issue.
                    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                    04-08-2024, 03:40 PM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • renech
                    panasonic TH-42PC77U plasma television half screen problem
                    by renech
                    hello,
                    I hope someone on this forum can assist me.
                    I have a panasonic TH-42PC77U plasma television.
                    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                    I have read some posts that suggest the problem is related to the boards on the left...
                    12-12-2022, 06:53 PM
                  • Zelek11
                    Panasonic Plasma screen interference on left half of screen
                    by Zelek11
                    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                    10-14-2022, 04:54 PM
