Panasonic cf 20 will no longer boot-only black screen
  • Rescogitans
    • Sep 2022
    • Usa
    Hello all. Only my second post.
    I have a panasonic CF-20C5142VM which was booting to bios with no issues. I needed to add an ssd that was not initially being recognized by the bios. Found a link that suggested that I disable uefi mode and clear keys then to reboot to allow bios to now see New ssd. After restarting, screen is entirely black with no image. Found another post that suggested unplugging bios battery because some remnants of the bios may still exist in other parts of board but did not fix issue-screen is still black.
    Anyone run across something like this before? Panasonic does have bios updates on their website but these are .exe files.
    In the past I was able to create a bootable usb to update bios with HP's but not with Panasonic.
    Suggestions??
    Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Panasonic cf 20 will no longer boot-only black screen
    You need to desolder the bios chip and program it with a spi programmer.
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • mitchw
      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
      by mitchw
      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
      04-29-2025, 03:45 PM
    • BlueNitesFire
      I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
      by BlueNitesFire
      So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
      03-08-2025, 03:49 PM
    • Technodoc
      ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
      by Technodoc
      Asus laptop G614JZ-N3012W Rog Strix with i7
      Mainboard G634J-PMV-VGT
      6050A3441302-MB-A01
      2023-02-10
      Power button works okay....power light goes on
      Red "bottom" leds go on
      Charging led works
      Fans do not spin, capslock key does nothing, screen stays black
      I would like to program the bios again, to rule out a corrupted bios.
      However I run into a size error
      The bios chip is a Winbond 25R256JVEN
      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
      02-24-2025, 04:46 AM
