Samsung LE32M87BD - stuck in standby - blinking LED
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Hi all
    This is my first attempt at an LCD repair
    When plugged in the LED blinks 5 times then trys to power up the screen
    Back light comes on for a second then goes off and the LED starts blinking again
    If i leave it plugged in for 5 min then the back light will power up but nothing responds on the TV except off on the remote or button then the cycle starts again
    attached are photos
    can you advise me on where to start as i said this is my first LCD tv as i have only worked on plasma's
  • smai
    • Dec 2013
    • 69
    Re: Samsung LE32M87BD - stuck in standby - blinking LED
    disconnect the the inverter board , turn it on, same cycling or different result ?
      Is it me or is one of those capacitors on the power supply slightly bulging?
      • noledud
        • Dec 2013
        • 413
        • united kingdom
        Samai - when the power is removed from the inverter board i get 6 flashes then off for a min then 6 flashes again, no more back light coming on
        tom66 - must be the pic iv triple checked and all look ok
        • noledud
          • Dec 2013
          • 413
          • united kingdom
          there was a screw missing from the PS so some one has been inside here also on the back of the PS there is some stickers, they are not ment to be there so the PS has been replaced at some point it looks like
            Check voltages on PSU outputs. Are they labelled?
            • noledud
              • Dec 2013
              • 413
              • united kingdom
              yeah they are but i have no way to stick my DMM in when the plug is connected - sorry if im being thick
              • noledud
                • Dec 2013
                • 413
                • united kingdom
                have i got to bridge 2 pins to turn the ps on so i can check voltages at the plug ?
                  You can just press your probe into the point where the sheath meets the pin.
                  Is there a BN44-####### part number printed on the PSU somewhere? (# = any digit)
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    bn44-00156B - im not sure what you mean, if i push from the top i get no readings as its not touching the metal - if i take the plug out i can then reach all the pins to measure.
                    • noledud
                      • Dec 2013
                      • 413
                      • united kingdom
                      here is a pic of the connector plugged in my probe wont fit any where
                      • anotherdude
                        • Feb 2013
                        • 488
                        your probe will go into the connector pins, where the wires are
                        • noledud
                          • Dec 2013
                          • 413
                          • united kingdom
                          me being thick im getting readings from the mainboard end not the PS end - i will post all in 1 min
                            I do literally just press the probe into where the wire meets the connector, with it installed. With light pressure your probe will touch the metal sheath around the pin which is usually less than a mm in. You can also use the metal chassis as ground.
                            I don't have a schematic for this PSU unfortunately, but I found this service manual:
                            Page 132 - pin outs.
                            "B" volts - active when not in standby
                            "A" volts - always active
                            Main_PWR_CTRL - on/off signal to PSU
                            • selldoor
                              Slow Learner
                              • 7870
                              If your probe pins are too fat , a lot of people have used a sewing needle inserted into each
                              socket hole and take the reading off the needle
                              • noledud
                                • Dec 2013
                                • 413
                                • united kingdom
                                brill thanks
                                ok here they are as you look at connector
                                0.01 - 0.01
                                12.05 - 12.05
                                0.00 - 12.05
                                0.00 - 0.00
                                5.40 - 5.40
                                5.40 - 5.40
                                0.00 - 0.00
                                0.00 - 0.00
                                11.99 - 11.99
                                0.00 - 0.00
                                0.00 - 5.22
                                0.00 - 3.41
                                • noledud
                                  • Dec 2013
                                  • 413
                                  • united kingdom
                                  23. 0.01 - 0.01
                                  21.12.05 - 12.05
                                  19. 0.00 - 12.05
                                  17 0.00 - 0.00
                                  15. 5.40 - 5.40
                                  13. 5.40 - 5.40
                                  11. 0.00 - 0.00
                                  9. 0.00 - 0.00
                                  7. 11.99 - 11.99
                                  5. 0.00 - 0.00
                                  3. 0.00 - 5.22
                                  1. 0.00 - 3.41
                                    Are those 12.05V lines testing at 12V or 13V? Just to check, they are marked 13V on pin out.
                                    • noledud
                                      • Dec 2013
                                      • 413
                                      • united kingdom
                                      12v
                                      • noledud
                                        • Dec 2013
                                        • 413
                                        • united kingdom
                                        when the back light fires up for a split second they then drop to nearly 0 but the back light goes off just before and they go back up
                                          09-07-2024, 05:50 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Ukdigger
                                          Samsung UE46f5000AK Stuck on Standby
                                          by Ukdigger
                                          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                          PSU number bn44-00610A L46SF_dpn
                                          1 B13v 12.4
                                          3 B13v 12.4
                                          5 Vamp 12.4
                                          7 Vamp 12.4
                                          9 GND...
                                          08-08-2024, 09:17 AM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
                                        • rju
                                          Samsung 60" Plasma TV, Blinking Standby LED
                                          by rju
                                          A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                                          Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                                          Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                                          07-21-2020, 05:23 AM
