Vizio e470vl logo turns white but no picture
    Re: Vizio e470vl logo turns white but no picture
    The line that feed the "On/Off" (cut the wire long enough so you can splice it back together if you get the new board).
    I am surprised you asked, since that is the pin you put the resistor to it to force it on, right?
    • ruben6805
      • Jan 2014
      • 15
      yes that is the one that i used the resistor. Just making sure because i dont have to much experience repairing tvs. ill try that. ill also look for a board. thanks
      • ruben6805
        • Jan 2014
        • 15
        replaced board with one that i bought from ebay and it worked. only thing is that my HDMI arent working. any ideas?
        • Super360
          Vizio E701i-A3 Vizio logo flashing then turns off
          by Super360
          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
          07-25-2024, 07:06 PM
        • ossroy
          Vizio M60-C3 powers on, perfect logo, turns off
          by ossroy
          Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
          My kids are getting antsy waiting...
          08-03-2022, 08:11 PM
        • Daveleone
          Vizio VO42L, white logo, no backlight, no picture
          by Daveleone
          Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
          From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
          I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
          Main board:
          Continuity across...
          02-20-2021, 04:52 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • x_orange90_x
          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
          by x_orange90_x
          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
          12-28-2023, 06:26 AM
