Testing LCD Tcon Pinouts
    Hi Guys,
    What is the best test for LCD TV Tcons other than replacing them with a good spare? I understand that the newer Tcons are able to be jumped with wireto display a test pattern. Not as easily as the the Plasma Tcons though.
    I have got Ebooks from several of the well known TV repair sites and its not there either. I tried Google got every thing except what I am looking for.
    Does anyone know what pin #44 of the LVDS wire cable is? What about pinouts to the TCON with the Dual Flat Ribbon Cablles?
    Ltank
    Re: Testing LCD Tcon Pinouts
    When you get the spec sheet of the LCD panel, it will give you the pin out and the requirement to run the T-CON, INVERTER, etc. There is no standard pin out for the LVDS connector.
    As you can see, the panel from the same manufacturer does not have the same pin out.
    https://www.badcaps.net/forum/showth...LN32A300J1DXZA
      Its a Shame the TV manufacturing companies can't agree on a standard. The Computer companies standardized the power supplies, USB, Serial ATA, main board card slot expansion slots. At least HDMI and Fiber connections are standard. Wouldn't our lives be a lot easier if it was standardized? You could build a TV as easily as a Computer! They almost stopped giving Schematics in Service Manuals because they want you to buy a new TV or replace the board instead of repairing it, in our Throw Away Society
        I agree, it is such a waste of earth resources.
          At least they standardised on inverter pin out, more or less. LVDS might be standardised after the move to 4K or AMOLED
