Vizio 47 vo47l
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Vizio 47 vo47l
    Hi all I have been rebuilding the boards on this tv for a while now.
    Now I an stumped There is a symbol on the back side of my power supply
    marked with a black arrow . I have no clue as to what it is. It is under a transformer. Any one know what it is?
    Re: Vizio 47 vo47l
    That is the Thermistor (can be Positve or Negative type) for temperature sensing, OTP= Over Temperature Protection. It looks like Negative type (NTC).
    What is the power supply not doing?
    • splitcrete
      • Dec 2012
      • 387
      • usa
      Re: Vizio 47 vo47l
      No 24 volt
      • splitcrete
        • Dec 2012
        • 387
        • usa
        Re: Vizio 47 vo47l
        The transformer that it is under will not power up.
        • splitcrete
          • Dec 2012
          • 387
          • usa
          Re: Vizio 47 vo47l
          Its the big transformer at bottom of picture.
          • splitcrete
            • Dec 2012
            • 387
            • usa
            Re: Vizio 47 vo47l
            I just checked the thermistor By warming it up with my solder iron and the resistance goes up . It is a negative type heat will increase resistance. A PTC is positive and the resistance goes down when heat is applied. Thank You BUDM for telling me what it was.
              Re: Vizio 47 vo47l
              Negative type, resistance goes down as the the temperature goes up, opposite reaction for PTC.
              Do you get about 380~400VDC at the two legs of the main 450VDC filter cap when PS_ON is applied to the power supply board? Board numbers?
              http://en.wikipedia.org/wiki/Thermistor
              • splitcrete
                • Dec 2012
                • 387
                • usa
                Re: Vizio 47 vo47l
                I will have to solder a couple wires under the board to find out.The cap is in a heat sink cage.
                  Re: Vizio 47 vo47l
                  For the 12v/24v switched power supply to work, it will need PS_ON, PFC Voltage booster circuit to work to supply 380~400VDC for the power MOSFETs that drive the 12V/24V transformer to run on.
                  • splitcrete
                    • Dec 2012
                    • 387
                    • usa
                    Re: Vizio 47 vo47l
                    Its getting late here I will report back tomorrow. The set I am working on has all volts good but no 24 volt from the big transformer. I changed all the radial caps but not the big one. And I changed all the regulators on the inverters, and main board.All fuses good pson is good and back light control voltage is good,and the panel is good too.Need sleep now I don't need to fry myself working on this piece of crap. Thanks BUDM good night
                    • splitcrete
                      • Dec 2012
                      • 387
                      • usa
                      Re: Vizio 47 vo47l
                      OK I had to check I am getting 398 volts.
                        Re: Vizio 47 vo47l
                        OK, that is good, so we need to concentrate on the 12V/24V drive circuit next. We will have to trace out the connections on the board. Do you have P/N of this board, we will need good clear pictures of both sides of the board, they must be good enough to clearly see the traces.
                        • splitcrete
                          • Dec 2012
                          • 387
                          • usa
                          Re: Vizio 47 vo47l
                          I have p/n and I will take some good pictures right now.
                          board number is 0500-0510-0340 be back in a couple minutes picture time.
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            Re: Vizio 47 vo47l
                            Got the pictures you asked for
                            • splitcrete
                              • Dec 2012
                              • 387
                              • usa
                              Re: Vizio 47 vo47l
                              Wrong picture
                              • splitcrete
                                • Dec 2012
                                • 387
                                • usa
                                Re: Vizio 47 vo47l
                                try this one
                                • addytzu123
                                  • Mar 2013
                                  • 54
                                  • ROMANIA
                                  Re: Vizio 47 vo47l
                                  The correct PS name is DPS-433BP , but unfortunatley I was unable to find a schematic for it!
                                  In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
                                  • splitcrete
                                    • Dec 2012
                                    • 387
                                    • usa
                                    Re: Vizio 47 vo47l
                                    I don't see a fuse but here is a picture.
                                    • splitcrete
                                      • Dec 2012
                                      • 387
                                      • usa
                                      Re: Vizio 47 vo47l
                                      Vizio didn't put out a schematic For this PS
                                      • Shane711
                                        • 493
                                        Re: Vizio 47 vo47l
                                        Did splitcrete ever figure out the problem? I am having the same problem, no 24v. I can not find the problem. There is 2 OPT Thermistors on the board and both read about 4 ohms with the board unplugged. I need help with this one.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
                                        • nbnb
                                          Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                                          by nbnb
                                          I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                                          Any idea what is causing the clicking sound? Any easy way to...
                                          11-23-2019, 12:03 PM
