Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
  • nbnb
    • Nov 2019
    • 13
    • usa
    I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
    Any idea what is causing the clicking sound? Any easy way to fix it or at least stop the clicking altogether? The TV works fine with the external speaker, but the clicking is annoying.
  • nomoresonys
    • 12307
    • U.S.
    Re: Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
    Quick check, unplug tv, hold power button down on tv NOT remote for 30 seconds, release it, plug tv back in and try it, might not work but it's an easy check.
    • nomoresonys
      • 12307
      • U.S.
      Can try a reset see if this one works: Press the "VOL-" button along the left side of the Vizio TV until the Settings icon in the shape of a wrench is selected, then press "CH-" until "Reset All Setting" is highlighted then volume+ or something like that.
      • nbnb
        • Nov 2019
        • 13
        • usa
        I've done both of those and neither helped. I took the back off the TV and it turns out the clicking sound is actually coming from the speakers.
        I may just use it with external speakers connected to the RCA jacks, and disable the internal speakers, if there isn't a quick fix for this.
        • nomoresonys
          • 12307
          • U.S.
          Could try a firmware update, you did go into audio or advanced audio settings and turn stuff off and on in there to see if it helped? Might have something to do with your audio circuit or speakers, most tv speakers suck, since the clicking is coming from the speakers and always there, the easiest fix would probably be to unplug the speakers at the speaker and black tape the wire terminals so they don't short on anything n just use external audio.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8342
            Can we see some high resolution pictures of the whole back side of the TV and the main board? Maybe add another one of the main boards audio section. If I recall there are tons of through hole caps on that main board.
            • nomoresonys
              • 12307
              • U.S.
              Probably is one of those caps, just looked at a similar one and has a shitload like you said.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8342
                either that, or the audio IC.
                • nbnb
                  • Nov 2019
                  • 13
                  • usa
                  Thanks for all of the replies. I went ahead and disconnected the internal speakers and will just use external speakers connected to the RCA jacks.
                  • ggil44
                    Vizio M65-E0 No Picture, No Sound
                    by ggil44
                    Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                    09-03-2024, 08:30 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Sisko
                    Onkyo-593 No power and now clicking sound
                    by Sisko
                    Hi all!!
                    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                    10-03-2025, 02:18 PM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • B0r1s
                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                    by B0r1s
                    PSU - BN44-00878A
                    Symptoms:
                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                    A weak clicking sound was coming from the transformer.
                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                    Progress:
                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                    01-17-2023, 04:58 PM
