big shadow on LCD screen
+ More Options
Posts
  • paulstef
    • Dec 2013
    • 724
    Hi , I'm a bit lost here.
    This is a Viewsonic LCD TV 37" N3752W. I replaced all caps on the power supply secondary, they were all bad.
    Now the TV is running but has like a big shadow on the left side. It is much more visible when the picture is darker (but not black). So for the second picture I turned down brightness to zero. Is this a panel/backlight problem? I can't think that this would be caused by something else (PCB )
    Thanks for reading
  • freakaftr8
    • Oct 2012
    • 3743
    Re: big shadow on LCD screen
    I would be inclined to say either it's a panel problem or there is something going on underneath it. Like dirt. Pull the lvds from the tcon and power up. Does the back light look even or is that dark spot still there?
      I have this same thing on my SAMSUNG 32", took the panel apart, removed and clean all the diffusers, polarizers, etc, without any affect. I think the only thing left is the problem on the LCD glass panel itself.
      • paulstef
        • Dec 2013
        • 724
        Ok, I'm gonna check this.
        • paulstef
          • Dec 2013
          • 724
          I don't really feel like taking the panel apart. Since I never did it I think it would be worse afterwards.
          I can still use it as a computer monitor or put it aside as a replacement when my main TV dies.
            What I try to say is that cleaning the panel did not correct the problem in my case, I had to replace my panel.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              i think this is a "mura"problem,caused by either bad lcd,bad diffuser sheets.
              normally this problem is terminal and will get worse.
              fix: replace panel if cheap enough.
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • paulstef
                • Dec 2013
                • 724
                Thanks guys,
                this is bad news. The TV is seven years old, ANY price for a new panel will be too high. You can get 37" TVs for $350.
                Where are the good old times when repairing something was actually worth it ? The times where a simple new TV cost $2000. :-)
                • SeanB
                  • Jun 2013
                  • 41
                  • South Africa
                  It could have been in a room where dirct sunlight hit that part of the screen during the day, which can do that with time. Best bet is keep it, and look out for a broken one of the same model to use as a screen donor. A totally non working one with a dead power supply would probably be best and should be cheap.
                  • paulstef
                    • Dec 2013
                    • 724
                    Is anywhere described what EXACTLY is causing this?
                    Also, Budm, do you have a good reference somewhere on how exactly take apart an LCD panel. What to do and what not? In the end you replaced the whole panel and all was good?
                    thanks
                    • tvtanner
                      tvtanner
                      • Feb 2014
                      • 70
                      • usa
                      Had trouble with sanyo tv with similar trouble and it was ribbon cable that feeds info to the glass panel. I pressed down on cable with hand and it went away so I taped a piece of sponge rubber across ribbon to repair. You have to remove band from around glass panel in order to do this. Check this site on sanyo troubles and you will see similar trouble. Good luck.
                      • paulstef
                        • Dec 2013
                        • 724
                        Will check. Thanks.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Had this just recently, a Toshiba 37" set. I had repaired it and put it up for sale. The picture was fine--no sign of this effect.
                          By the end of the day,--There it was, a dark shapeless splodge just off centre of the screen.
                          The next day when the set and W/S, Shop was cold--No mura...
                          That afternoon--back it came....
                          The shop W/S is made in a steel shipping-container, thats very cold in the morning but is orientated in such a way that if its sunny--you cant keep your hand on the wall!
                          How depressing--Sold it off very cheap!
                          TELEFIX
                          • paulstef
                            • Dec 2013
                            • 724
                            Mine gets a little better when it's turned on and heats up after a while.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Possible diffusers are warping under heat. Only other way to tell is disconnect tcon and see if the dark spot is still there or.take it apart and use an external light to shine thru the panel and see if its there. If it is panel is bad
                              • Mgiffune
                                by Mgiffune
                                I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                I ordered a supposedly β€˜new' Tcon board this time, and
                                06-09-2024, 10:28 AM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • arbitarytwist
                                Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                by arbitarytwist
                                Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                03-01-2025, 01:16 PM
                              • nasdaa
                                Packard Bell Kayfo, no picture on screen.
                                by nasdaa
                                Hello, I need your help for a failure on a laptop:
                                It's a Packard Bell Kayf0, motherboard LA-5021P, Rev 1.0 with graphic issue.
                                I received this pc because it was turning on but not displaying anything, the fans are running normally and all chipsets heat up on startup but no picture on screen, no backlight either. I noticed that ENAVDD and ENVDD are not present and that there is no LCDVDD on the connector. I didn't check the screen because, maybe I'm wrong, but if there aren't these signals, even if the screen is good, it can't display anything? I tried heating the...
                                06-20-2023, 01:27 AM
                              • burbutsalos
                                LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
                                by burbutsalos
                                Hello everyone.
                                I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
                                The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
                                The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
                                The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
                                The effect is there even on a completely black screen.
                                The screen...
                                10-21-2023, 02:57 AM
