Vizio TV Model e321VL stuck on Vizio logo screen
  • moonwolf12
    • Jan 2014
    • 6
    Hello! After the disappointment of my TV not working I researched on the internet and learned that particular model was prone to the stuck on the VIZIO logo problem.
    I tried factory resetting it but it didn't work, so I took the back off and took pictures for you guys. I know nothing of TV's, so I can't identify a loose/bad connection just by looking at it. I'm so willing to put in the effort of fixing this, I just don't know where to start.
    I know that there's already a lot out there on VIZIO TVs with similar problems but I can't use those resources without first identifying the main problem. That's where I'm hoping you lot can help.
    I'm not sure if this is relevant or not but I first encountered the problem 3 weeks ago. It was the week I was leaving my college for winter break so instead of trying to fix it I unplugged it and left for home. When I came back from break I plugged it back in and it turned on! I was so happy. It worked for two days, and then I plugged my computer in using an HDMI cord, used the TV and unplugged the cord. Later that night it didn't turn on :'(. When it stopped working the first time it was right after I unplugged my computer from the TV via HDMI again.
    It could have nothing to do with the main problem but I don't believe in coincidences. At the same time I feel like HDMI can't break a TV like that.
    Anyways, any advice you guys can offer will be worth a million! Thanks in advance.
    Here are the pictures I took, hopefully they are clear enough:
    http://imgur.com/a/RuLOp#OW9or2B
    Last edited by moonwolf12; 01-11-2014, 02:58 AM. Reason: Forgot to include IMGUR album
  • Gorrillasnot
    • Dec 2013
    • 316
    Re: Vizio TV Model e321VL stuck on Vizio logo screen
    I'm a newb when it comes to TV repair myself so wait for the more experienced folks to give you advice, but after doing a brief google search it appears the problem could be a bad eeprom.
    If the eeprom needs to be replaced it would require soldering. If you don't feel comfortable doing the soldering yourself I saw a repair service on ebay that's $45 or you could buy a replacement main board for around $50 (used on ebay) or $70-$85ish new @ shopjimmy.com).
    Again I could be wrong so don't do anything until you get more replies from the more knowledgeable folks here. I was just bored and figured I would research it a bit for you.
    good luck
    • vinceroger69
      • Mar 2012
      • 6714
      try some of these tests and post results
      https://www.badcaps.net/forum/showpo...46&postcount=9
      • moonwolf12
        • Jan 2014
        • 6
        What's the device called that I need to check the voltage on these fuses?
        • vinceroger69
          • Mar 2012
          • 6714
          voltage regulator are the three legged devices and yoy need to see what the voltage is on each end of the fuse have you got a multi meter? if you have and not sur what setting to put the meter on post a picture up and we can advise you is your main board exactly the same as the one in the picture?
          • moonwolf12
            • Jan 2014
            • 6
            Yes the pictures are from my TV, I'll post closer pics whenever I get the readings. I have to go out and buy one, thanks for your help. Do I need a voltage regulator and a multimeter or just one of those two? I don't want to spend any more than I have to.
            • freakaftr8
              • Oct 2012
              • 3743
              Check all voltage regulators. 3 pin ones on the mainboard. Ones probably out of spec. U18 possibly. On the power supply probe the ps_on pin and press power on button. Do you get 3 when pressing the button?
              • vinceroger69
                • Mar 2012
                • 6714
                a multi meter for a start the rest you can order on line if needed/want to.
                • moonwolf12
                  • Jan 2014
                  • 6
                  I haven't bought a multimeter yet to check, it'll probably be a couple days but as soon as I get those number's I'll let you know.
                  • moonwolf12
                    • Jan 2014
                    • 6
                    Ok thank you!
                    • x_orange90_x
                      Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                      by x_orange90_x
                      I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                      12-28-2023, 06:26 AM
                    • paulxxxx
                      Vizio E701i-A3 stuck at logo, need service manual
                      by paulxxxx
                      The TV stuck at logo and cannot be turned off unless the cord is unplugged.
                      I was given two main boards and exactly the the same thing happens to both of them.
                      I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
                      There are no signs of damage on any of the 3 boards.
                      Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
                      Thanks!
                      09-08-2023, 01:11 PM
                    • G33RT
                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                      by G33RT
                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                      It does power up when pressing the power button.
                      I already try the power button while plugin the plug with no result.
                      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                      Could this be an PSU or eMMC issue ?
                      07-19-2025, 03:43 AM
                    • Bob1394
                      Vizio M65-C1 | Logo appears for 10 seconds then off
                      by Bob1394
                      I have used the search, and am stumped.
                      My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                      I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                      https://www.badcaps.net/forum/showthread.php?t=81088
                      https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                      Observations
                      1) [Interaction] Power turned on via TV button (or remote)...
                      02-08-2023, 01:03 PM
                    • justice171
                      JVC LT-50N795 Stuck on Wisdom Share Logo
                      by justice171
                      I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                      It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                      Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                      Thanks in advance!
                      11-04-2024, 02:55 AM
