HP Plasma PE0000
  • freakaftr8
    • Oct 2012
    • 3743
    Re: HP Plasma PE0000
    yes but if there is a problem it would do it after it warms up if you have a weird pictureand it's all pixelated from cold start up then there is other issues like the other members said there could be a regulator issue or capacitors over driving the IPM.
    and don't think you're going to annoy us by asking too many questions. that's what we're here for to ask questions and get questions answered
    • jasonflippin
      • Jan 2014
      • 52
      I will get the caps replaced as mentioned and report back. I think I may have them on hand so probably can do that tonight. Also, I will send a pic of the pieces that fell out tonight just so you know which they are as I am not sure of their names.
      If you think that oscilloscope would be beneficial, I will get it ordered. I plan on making this a common use of my time if I can learn enough so I don't think it will go to waste. But, I do not have a clear understanding as to how often an oscilloscope is used or needed either in these cases.
      Thank you guys for the help.
      • jasonflippin
        • Jan 2014
        • 52
        Ok, these are the pieces that I had to resolder. And here they are soldered back on. Not perfect by any stretch but appear to be in there good.
        I don't have any of the 100UF v35 just 180UF v35 so I will need to order some of those
        Is there a way I can narrow down the problem. Here is a video of what it looks like if this helps any.
        http://youtu.be/t-EOlpXxhOY
        Thanks!
          I don't think those smd caps are supposed to look like that. I recently had to do some so I came up with the best method I could. I tinned both pads (tiny bit of solder on them. I then slid the cap onto one end, heating the pad as I did. Once the cap was fully on, one pad was done. I then applied a -small- amount of solder to the other end and verified the joint with a loupe.
          To be honest if you can it might work better to solder a through hole cap on the SMD pads.
          • jasonflippin
            • Jan 2014
            • 52
            Sorry for my ignorance. The SMD caps are the silver caps? So, you are saying instead of trying to solder the joint directly you just heated up the whole cap itself? And a loupe is basically a magnifying glass to confirm you have a solid joint? I'm not completely sure I am following when you say solder a through hole on the SMD pad. I'm sorry but do you mind explaining?
            What exactly do these caps do? Same thing as normal caps? Just a surface mount variation?
            • jasonflippin
              • Jan 2014
              • 52
              Originally posted by Alastair E
              --I did replace all the 33 and 68uF caps around the three 15V regulators on the Y-SUS of both sets, these 15V rails supply amongst other things the IPM switching drive voltage and if low can cause the IPM to get hot/fail.....
              --There's only 6 of 'em and easy to change, might as well do them, Use 100uF 35 or 50V to replace the hideous S.M. ones the makers used.....
              Alastair - I just wanted to clarify, you replaced the 33 and 68uF caps with the 100uF 35v? Or did I misunderstand? I was going to order the caps tonight but wasn't completely sure.
              • jasonflippin
                • Jan 2014
                • 52
                None of the caps appear to be swollen. Would it still make sense to replace them?
                • DrDos
                  Wierd reading on my multimeter
                  by DrDos
                  I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
                  09-12-2025, 04:44 PM
                • starmaxpc
                  LG 50ps60 Plasma Grainy/Fuzzy Horizontal
                  by starmaxpc
                  hi fellas. i picked a freebie locally it is a lg 50 inch plasma with display issue. tv turns on i can navigate thru the side button controls volume is good channel up down etc. looking thru the other postings on this system there seems to be a variance of different issues with this model. any direction as what would cause this display issue. sorry my pics are sideways as i don't have the stand and the darn thing weighs a ton. Thanks....
                  02-27-2021, 07:10 PM
                • SuperAman
                  PS5 HDMI port diode reading?
                  by SuperAman
                  I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                  02-03-2024, 10:16 PM
                • TURSTY
                  Replacement IGBT's for LG TV reading weird
                  by TURSTY
                  Hi guys,
                  I have a LG Plasma that went bang one night.
                  Long story short, I took it to a "professional" shop to repair the YSUS board that was shorted and they did a half ass job.
                  I'm a long way down the path of teaching myself component level repair, but not 100% confident in everything yet, hence what might be a basic question.
                  The repair shop replaced 3 transistors on one of the two heat sinks and fixed one short, but the second set of transistors on the second sink still had a short.
                  So I removed this sink...
                  08-01-2023, 07:38 PM
                • trex66
                  Craftsman 82345 Multimeter broke!
                  by trex66
                  My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                  03-04-2025, 04:26 PM
