HP Plasma PE0000
  • freakaftr8
    • Oct 2012
    • 3743
    Re: HP Plasma PE0000
    Dumb question but is the fuse you put into the Zsus good? I've done things like this before and scratched my head for hours over something simple. Lol
    • jasonflippin
      • Jan 2014
      • 52
      yep, I bought new fuses and tested it. I believe I can return the board there was a DOA policy with the purchase. I can try to find a local guy that has more experience in soldering the IPM in if that sounds like it would make sense. Is it a special way of soldering or something like that? Just curious what I would ask.
      • freakaftr8
        • Oct 2012
        • 3743
        Ok here's what I would do. return that board if he has a DOA policy. It's obviously bad. If you don't feel like ordering another board then take your old board and start with that on trying to remove the module.
        others on this forum may disagree but after much trial and error I take a piece of bicycle inner tube or plastic and I put it underneat large flat head screwdriver. then I carefully prior up on one side of the module breaking it free from the board. Of course the pins are still in the board then the other side is still connected after you free the one side I wiggle the module back and forth until the pins break off. after the module is removed from the board I now apply solder to each pin and I use a pair of needle nose pliers and carefully pole each pin from the board. Then I use a soldering iron and a solder sucker and remove the solder from each hole. Then the board is ready for the new module. It is very time consuming but my concept keeps the board from getting scorched its rudimentary but it does work
        • jasonflippin
          • Jan 2014
          • 52
          OK, you weren't kidding, that was extremely hard. I couldn't get anything in to snap the IPM module off, so I tried another post I saw in here in which they heated the solder points up with a heat gun. (https://www.badcaps.net/forum/showthread.php?t=33684). I was able to do that and finally got it to come off but I had to do it on high with my heat gun. I tried on low for 15 minutes and couldn't get any of the solder to budge. Once I finally got the solder to loosen up the board had a small bubble in it since it must have gotten too hot but has since gone down. I can't even tell where the bubble was at this point. But, my question is, is the board toast or should I continue to press forward with the IPM replacement? Is there a way to test that or confirm one way or another? Also, some other small transistors loosened up and came out as well but I think I can get those soldered back in relatively easy.
          • jasonflippin
            • Jan 2014
            • 52
            Going to follow up with one more question quick -
            If the board isn't bad, I was able to find the IPM at a place called yaspro for $1.00.
            http://www.yaspro.com.cn/products/2300KCK004A.html
            Seems to good to be true so thought I would ask if anyone had any experience with them or if I was looking at something wrong.
            The number on the inside of the IPM says LGIT - 2300KCK004A
            • jasonflippin
              • Jan 2014
              • 52
              Any ideas?
              • freakaftr8
                • Oct 2012
                • 3743
                when you remove that module did you flip it upside down and see if any components were shorted out you will see a black or grey charred area area underneath the silicone
                • jasonflippin
                  • Jan 2014
                  • 52
                  I did, there was a few connections that looked shorted out and the silicone looked burnt in places.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Never heard of that company. I'm usually weary of cheap ipm modules.
                    • jasonflippin
                      • Jan 2014
                      • 52
                      Where do you usually pick up IPM's from? Any reason for concern on the board bubbling?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        If you didn't break contacts or traces should be OK. Where is the bubble at? Output side or input where 18v and grounds are?
                        I get my modules usually from Coppell but any reputable seller on eBay I have had luck with.
                        • jasonflippin
                          • Jan 2014
                          • 52
                          It bubbled on the bottom of the board (output side?) and was the opposite side of the grounds (they are labeled ER_DN, ER_COM, ER_UP to name a few). I don't see any of the traces or contacts broken, but I only see traces on the top of the board and only solder points on the bottom.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            As long as the hole-thru studs stayed in the board you should be ok
                            • jasonflippin
                              • Jan 2014
                              • 52
                              OK, I got the IPM in tonight and I can actually see the picture. It looks great except when there is movement on the screen. It seems like there is a refresh issue or something like that. If the screen is static and doesn't change it looks perfect. I will try to post a picture but its been problematic trying to capture a picture when its flickering. Any idea on what could be causing that? I changed my settings to 720p just to rule that out and then tried an xbox at 480p which both did the same refresh thing. Definitely close.
                              And thanks for all the help. I would have never made it this far without you guys!
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                that looks like you have a voltage adjustment ooff. check the VS voltage against the label on the panel. also did you happen to adjust any of the pot on the Y sustain board?
                                • jasonflippin
                                  • Jan 2014
                                  • 52
                                  Where do I check voltage? I will check the label and post what I find on here but wasn't sure if you wanted me to use the multimeter to check voltage somewhere.
                                  The Y sustain board I haven't touched yet.
                                  • jasonflippin
                                    • Jan 2014
                                    • 52
                                    I tried to do a little research on this but having trouble locating the VS test location on the power supply. Would it be called anything else?
                                    Here are a few pics if it helps any
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      The wires coming g out of the connector on the lower left side of the.power supply in pic 1. There will be a pin labeled VS. Check that pin against the label on the back of the panel. Should be around 190 to 210vdc. Also check the VA output pin as well.
                                      Let's start there.
                                      • jasonflippin
                                        • Jan 2014
                                        • 52
                                        OK, looks like TV is set for 187 based on the sticker inside and when I test both VS input's I am getting 177. VA is set for 65 and getting about 64 off of it.
                                          You should try increasing Vs until it meets panel spec, there is a little screw adjustment on power board. Get Vs and Va within 1V (no need to adjust Va in this case.)
                                          • DrDos
                                            Wierd reading on my multimeter
                                            by DrDos
                                            I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
                                            09-12-2025, 04:44 PM
                                          • starmaxpc
                                            LG 50ps60 Plasma Grainy/Fuzzy Horizontal
                                            by starmaxpc
                                            hi fellas. i picked a freebie locally it is a lg 50 inch plasma with display issue. tv turns on i can navigate thru the side button controls volume is good channel up down etc. looking thru the other postings on this system there seems to be a variance of different issues with this model. any direction as what would cause this display issue. sorry my pics are sideways as i don't have the stand and the darn thing weighs a ton. Thanks....
                                            02-27-2021, 07:10 PM
                                          • SuperAman
                                            PS5 HDMI port diode reading?
                                            by SuperAman
                                            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                            02-03-2024, 10:16 PM
                                          • TURSTY
                                            Replacement IGBT's for LG TV reading weird
                                            by TURSTY
                                            Hi guys,
                                            I have a LG Plasma that went bang one night.
                                            Long story short, I took it to a "professional" shop to repair the YSUS board that was shorted and they did a half ass job.
                                            I'm a long way down the path of teaching myself component level repair, but not 100% confident in everything yet, hence what might be a basic question.
                                            The repair shop replaced 3 transistors on one of the two heat sinks and fixed one short, but the second set of transistors on the second sink still had a short.
                                            So I removed this sink...
                                            08-01-2023, 07:38 PM
                                          • trex66
                                            Craftsman 82345 Multimeter broke!
                                            by trex66
                                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                            03-04-2025, 04:26 PM
