samsung le32s86bd main board or psu fault?
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: samsung le32s86bd main board or psu fault?
    Originally posted by charlierfc
    What board, the psu? Or the main board.
    I do have a capacitence tester...and a hair drier lol, but its hard to pin point as it sometimes works strait away. Would a cap problem cause screen distortation? Last time it cam on with bit of yellow distortation allomg the screen. Its fine this time though
    yes caps could cause that,if a cap supplying the tcon rail is failing then voltage would drop.
    its the psu,heat all the caps ,and monitor if the fault happens again,if the caps are failing it may bring them back just enough to work.
    id still esr them after though
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Even though those caps look good,--and marked with a pen (They all are in every one Ive seen!)
      --The fault you describe sounds exactly like iffy old caps on the supply-rails to me...
      The 1000uF 35V and the larger 25V caps are usually the cause....
      TELEFIX
      • vinceroger69
        • Mar 2012
        • 6714
        have you just been testing the capacitors for the uf reading as you do really need a esr meter if you havent got one if not just replace the lot imo for panasonics
        • charlierfc
          • Mar 2013
          • 93
          • scotland
          hi all, thanks for the replys. i will try pin point the faulty caps with heat. i only have a capacitence tester. iv been a bit busy.ill try heat the board see if it turns on 1st time before i even attempt to turn it on.
          thanks again for your input. i appreciate it.
          • charlierfc
            • Mar 2013
            • 93
            • scotland
            Hi all again, looks like anotherdude was right. Before any testing i heated the psu.the tv didnt come on. I then heated the mainboard near the shielded are.turned on 1st time and is still on.looks like failing mounted caps on the main board. So...loks like i need another main board!
            Ill oreder one and hopefully that will be the end of the matter.
            • anotherdude
              • Feb 2013
              • 488
              #26
              another bordeaux model failing, whats with samsung and these main boards
              • freakaftr8
                • Oct 2012
                • 3743
                Caps.on these mainboards come from different manufacturing facilities I notice.
                • mmartell
                  • Oct 2013
                  • 3189
                  Or just replace some caps ?
                  • charlierfc
                    • Mar 2013
                    • 93
                    • scotland
                    #29
                    Its the small mounted caps that are gone by the looks of it, i dont think maplins have these in stock?
                    Can they be replaced by normal caps with the same uf?
                      Yes, but do not use capacitors from maplins. Order them from CPC (free postage, no minimum order - you cannot go wrong) - and also, use Panasonic FM/FR/FC where possible. CPC also stock some smd caps but not many.
                      • Asraf Atb
                        by Asraf Atb
                        01-27-2025, 05:02 PM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        Yesterday, 08:34 AM
                      • Lee M.
                        Samsung UN75RU8000FXZA bad main board?
                        by Lee M.
                        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                        11-08-2023, 07:46 PM
                      • JDC
                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                        by JDC
                        ONN 100012588
                        Issue: No Power, Then Rebooting After Main Board Change
                        Short answer: replace main board and power board
                        Technical answer: replace main board and Q306 & Q307 on power board.
                        Long answer:
                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                        07-15-2022, 07:39 AM
