Weird ESR readings
  • cib3k
    • Jul 2011
    • 12
    Weird ESR readings
    I have an old LG CRT TV from 2001. The image expands when I turn the contrast up, and shrinks when I turn it down. I'm trying to see if I can fix this. I started testing capacitors (in circuit), and I've got some weird readings for 2 of them.
    The first one is 160V 100uF. When I try to measure ESR, I get a flashing -0. If I reverse polarity, I get the same -0. If I only touch the capacitor leads for a moment, I get some large values: 50, 90, even 100 ohms.
    Using my multimeter to measure resistance on the 20K scale, I get values that increase up to 2.8K and stabilize there. If I reverse polarity, the readings go almost instantly to infinity.
    The other capacitor is 250V 4.7uF. It gives no ESR reading. I cleaned the leads, made sure the probes are making proper contact, and I still get no reading. My ESR meter doesn't react at all when I touch the leads. Using my multimeter on the 20KOhm scale, I get values that go up to 11K. Reversing polarity, I get infinity.
    Does anyone know how to explain these readings?
    Re: Weird ESR readings
    What do you read when the cap is off the board? I never do ESR testing with cap on board due to other components may be connected in parallel with the cap.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Classic symptom of low EHT or very poor EHT regulation.
      I would suspect the Line-Output Transformer rather than a cap!
      TELEFIX
      • cib3k
        • Jul 2011
        • 12
        At the moment I'm just looking around, I'd rather not take components off board unless I'm quite sure they're bad. I prefer analyzing things rather than randomly disconnecting components. I'm a beginner and this way I'm trying to learn more about electronics. Thanks for the transformer tip, I'll look into it.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          In this case you better step away from electronics, because this spesific industry does not use your imaginary methods.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Follow the white rabbit.
            • cib3k
              • Jul 2011
              • 12
              Come on guys, as I said I'm a beginner. I've read about lifting tracks and irremediably damaging boards, so until I master component removal I stay away from that. And I need some dead boards to practice on. At the moment I'm studying mostly how things work, how to use meters, how to interpret ESR readings and so on. I learn a lot just by testing my TV.
              Also, while searching for more info on flyback transformers, I came across an electronics forum where a guy had just fixed the same problem on the same TV as mine by replacing a dried out capacitor. I checked and it was the one where my ESR meter gave that flashing -0 reading. So now I know what this reading means, and how to interpret it in case I stumble upon it again.
                Since you are the beginner, you should at least get the SCH of what you are working on, see how the suspected bad component is connected in the circuit, see if it has resistors, caps, transistors, diode, etc connected in series/parallel with it. You should also try measuring the spare parts you have and see what the read out are, etc. Build some circuits, take measurement of the part in circuit and off circuit and see the reading results of the reading when component is measured when it is connected to the circuit and when it is not.
                Also learn about safety when you work on the equipment.
                • Kiriakos GR
                  Banned
                  • May 2012
                  • 940
                  • Greece
                  Originally posted by budm
                  Since you are the beginner, you should at least get the SCH of what you are working on, see how the suspected bad component is connected in the circuit......
                  Because he is not ready for that part either he is skipping it for now.
                    Yes, he needs to learn the basic first, without good base of understanding of how each components work and know how to apply that knowledge, it will not be easy if you skip. Working on CRT that can have up to 30KV is not something to start with.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      well--
                      Recommend you get an old circuit board--from anything--and Practice Removing/replacing parts with solder-sucker and de-soldering braid. and a good reel of 0.5mm LEADED solder.
                      Forget the Lead-Free CRAP.
                      That way, you'll gain experience and confidence.
                      More often than not things HAVE to be removed to test properly.
                      TELEFIX
                      • vlady carp
                        Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
                        by vlady carp
                        Hello, colleagues!
                        I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
                        What I've done so far:
                        • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
                        • The original processor is beyond repair, and I wasn't able to extract the dump.
                        • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
                        01-16-2025, 02:08 AM
                      • Dev Goose
                        Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                        by Dev Goose
                        Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                        What Happened
                        The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                        12-13-2024, 03:13 AM
                      • Loki_Fido
                        (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                        by Loki_Fido
                        Hi folks,
                        This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                        I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                        BIOS - XMC 25RU128CH10 (1.8v)
                        What the heck is this? I looked all over the MB. This is the only bios.
                        When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                        03-20-2025, 01:57 AM
                      • Spoonicks
                        Samsung 2233SN no CFL backlight
                        by Spoonicks
                        Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
                        Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
                        I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
                        Following the guide I tested the following:
                        The transformer...
                        07-01-2023, 11:10 AM
                      • evelhorn
                        Weird voltage readings on old and new board
                        by evelhorn
                        I bought a new power board for a Vizio D55U-D1 that was reading 19.2v on
                        12v pins. The new board is giving me the same readings. This can't be normal
                        can it? These readings are the same even with the board isolated.
                        08-26-2019, 06:14 PM
