Weird voltage readings on old and new board
  • evelhorn
    • Nov 2014
    • 29
    • usa
    I bought a new power board for a Vizio D55U-D1 that was reading 19.2v on
    12v pins. The new board is giving me the same readings. This can't be normal
    can it? These readings are the same even with the board isolated.
  • nomoresonys
    • 12276
    • U.S.
    Re: Weird voltage readings on old and new board
    Been seeing lots of vizios lately with 19 volts: https://www.badcaps.net/forum/showthread.php?t=76708
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      why did you get a new power board first place? What is your TV doing or not doing?
      • R_J
        • Jun 2012
        • 9588
        They control the negative line for regulation using a fet driven by a SP6018e. However the sp6018 VDD is supplied by 7812 regulator ic which has its input connected to that same (12v) line so for the 7812 to function the input must be above 12 volts, so 19v would be about right. So I suspect the board IS labeled wrong
        • evelhorn
          • Nov 2014
          • 29
          • usa
          The TV would not come on the light would blink 15 times then go back red, was not getting any standby voltage only 19 on the 12-volt pens even with the TV off. saw a cheap power board on eBay and thought I would give it a shot
          • evelhorn
            • Nov 2014
            • 29
            • usa
            I was just wanting to know if anybody else had seen this and if it was normal
            • nomoresonys
              • 12276
              • U.S.
              Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on. So we can see all the voltages and what they are doing. Try to do test just as instructed, example in second link below if needed.
              • R_J
                • Jun 2012
                • 9588
                If you were getting a blinking led, You have standby voltage. Did you check pins 1&2 of CN9102?
                • evelhorn
                  • Nov 2014
                  • 29
                  • usa
                  Sorry for wasting your time guys it was the main board somebody spilled something on it the residue was still on the backside of it
                  • nomoresonys
                    • 12276
                    • U.S.
                    Thanks for the feedback.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • EasyGoing1
                      Weird issues with stray voltage on prototype board
                      by EasyGoing1
                      I moved a circuit from a breadboard to a standard generic PCB prototype board, and the circuit didn't work on the PCB board. Specifically, a small Arduino Wifi device wouldn't even boot while it was on the PCB board.
                      Naturally, I checked all of my solder connections under a magnifying glass and I triple checked the wiring to make sure it was consistent with the schematic. This is a VERY SIMPLE circuit ... maybe a total of 10 wires are involved at the most ... a couple of pins, a transistor, couple resistors, and an LED.
                      Ultimately, I discovered that I was getting voltages...
                      10-05-2020, 12:31 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
