Samsung LE26A457C1D Power problem, It Banged
  • aar5384
    • Jan 2014
    • 82
    • England
    #61
    Re: Samsung LE26A457C1D Power problem, It Banged
    Originally posted by tom66
    Ideally, yes. Then check on 2000 ohms between each pair of legs both forwards and backwards.
    dp802 495 with left leg + --- 0 with right leg +
    QP801S left leg + reads 010 when either other 2 legs negative
    centre leg + reads 010 when left leg negative and 0 when right leg negative
    right leg + reads 010 when left leg negative and 0 when centre leg negative
    going onto other 2 in a sec
    • aar5384
      • Jan 2014
      • 82
      • England
      #62
      QM801 left leg + gave 0 when both other legs negative
      centre leg + gave 0 left leg negative 590 right leg negative
      right leg + gave 0 centre leg negative 777 right leg negative
      • aar5384
        • Jan 2014
        • 82
        • England
        #63
        QM802 left leg + gave 0 when both other legs negative
        centre leg + gave 0 left leg negative and 582 right leg negative
        right leg + gave 0 left leg negative and 827 centre leg negative
          Looks like several bad FETs, really unusual!
          • aar5384
            • Jan 2014
            • 82
            • England
            #65
            Lol, so do all 4 look like there caput?
            Ive just burned me thumb loads getting them out and putting them back in lmao
            • aar5384
              • Jan 2014
              • 82
              • England
              #66
              I was looking at an alternative power board as a new one of these is not far off £80 new including postage, but the new one lists a couple of board numbers that my current board can be used in place of one being BN4400209A and is 30 quid inc postage, would a different one work? does look like same connectors
              • aar5384
                • Jan 2014
                • 82
                • England
                #67
                Well i started pricing up the mosfets and with the first two i checked being in a pack of 5 at a time it was looking at over £10 for the first two, then i lost interest thinking the other two were probably similar in price with no guarantee that something else might be caput on the board and just turn into a spiralling repair cost.
                As last night i saw the BN4400209A board number listed with my BN44-00214A board number, they both have a different layout but i got the circuit plan sheet and the outputs from the pinouts are a direct match for voltages and signals, is it safe to assume this alternative cheaper board will be a good retrofit?
                  Should be - if: it's for 26" or larger, and dimensions will fit.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #69
                    looking at the ebay link you posted yes should be fine.
                    • aar5384
                      • Jan 2014
                      • 82
                      • England
                      #70
                      Thanks for all help on this so far, this power board has been a bit of a human back end to me, hopefully when i order the alternative board it brings it back to life Thanks everyone
                      • ntsioupl
                        • Oct 2014
                        • 4
                        • greece
                        #71
                        hi!
                        i'm new to this forum without any expertise on the electronics field..but i have a natural quriosity on the pc and electronics.
                        i think this thread will cover my problem so i don't open a new one.i'm sorry for my bad english i'm greek and i'm rusty on the language.
                        well there is my story:
                        my mother in law has this 32'' samsung with the on-off problem. the tv was playing for several days and she didn;t switch it off because she was afraid it won't power up again.
                        so i said to her why not, I CAN FIX IT!
                        prior to this i had seen some youtube videos doing recap on samsung tv so i said i will do this and the tv will work!
                        i did the recap and i forgot one cut cap leg shorting a fet.
                        i pluged it in and the thermistor went on fire!!the fuse died too.
                        i somehow managed to burn my 10 $ multimeter too! it wouldn't read volts on anything.
                        then i bought a new expensive multimeter and i found that there where some diodes burn and some fets. i changed the fuse and the thermistor i pluged it and the tv started playing normally!
                        i screwed the back cover and lighted it on for another check. then it started smoking..
                        i unpluged it and then, once again i pulled of the power supply from the tv. i searched for visual signs of burn but there was nothing. i pluged it again with no ribbon on it and it didnt smoke.
                        then i connected the main board and it started smoking from the fets that are near the plug going to the mainboard.
                        i unplugged the main board and inverter and with the power on the supply i started measuring the volts that it was sending to mainboard and inverter
                        the first measurings made me thing that i blew my new multimeter again! with the black probe on several grounds on the ps board and the red on all the output pins i red 0,01-0,5 volts!
                        after an hour break to clean my head and calm my nerves i repeated the measuring on the ps's output pins to see in my surprise on every 12v and 5v and 24v pin - 60.something volts!
                        needless to say that in my attempts to she what was wrong i accidentally lifted one or two lines from the pcb but i jumpered on other points.
                        my mother in law is a tv freak and she's stuck with an old 14'' tv and keeps on asking when the tv will be fixed.
                        do you thing i should try to fix this ps board/ buy a new one [s or even buy a new tv to my mother in law and admit to my self that there are thing that i can and things that i can't do?
                        sorry for the length of the message..
                        thank you in advance!
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #72
                          clear pictures of the trace damage on the psu will help us you have probably jumpered one of the broken/lifted traces wrong is there a model number on the psu?
                          • ntsioupl
                            • Oct 2014
                            • 4
                            • greece
                            #73
                            the model is bn44-00214a
                            and here are some pictures
                            • ntsioupl
                              • Oct 2014
                              • 4
                              • greece
                              #74
                              anyone please?
                              • ntsioupl
                                • Oct 2014
                                • 4
                                • greece
                                #75
                                ok. i totally give up. i will buy a new one psu.
                                just one question. i found from a local store the bn44-00155a from a broken lcd for just 30 euro
                                the thing is that it has reversed the outs for the main board and the inverter board in comparison with the bn44-00214a that i'm replacing.
                                i thing that if the orientation is the only problem and i fasten it upside down it will fit.
                                can anyone confirm this?
                                • coreyand
                                  • Nov 2014
                                  • 88
                                  I just repaired this tv by replacing the 222k 1kv sm small cap by the big blue cap, and replaced the jumper next to it, as well as the other blue cap ( i dont remember the numbers on it but its circled in the picture ) And the tv is back to life now. Pretty easy fix for me this time.
                                  Attached an image of replaced components.
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • Duranitron
                                    Asus x512dk rev 2.1 power on problem
                                    by Duranitron
                                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                    11-26-2024, 10:22 PM
                                  • beetle1303
                                    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                    by beetle1303
                                    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                    01-13-2025, 08:49 PM
                                  • EazyBone
                                    LG OLED55C9PUA power problem
                                    by EazyBone
                                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                    The power supply to t con is different story.
                                    This...
                                    06-23-2023, 07:43 AM
                                  • bcstedt
                                    Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                    by bcstedt
                                    Just starting to crack into this one and wanted to get the ball rolling.
                                    At power on (plug in), power light on, relays click, repeat (sometimes)
                                    After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                    Removed Y-Main for inspection and testing
                                    This pic from:
                                    PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                    12-15-2023, 10:30 AM
