Vidao 32E66 will not turn on
  • Papajohn
    • Jan 2014
    • 13
    The orange light in the front turns on but nothing else happens.Removed back cover looked at the caps nothing puffy.Checked volts on wires where it's says 5v or 24v on the power supply that is what's there.
    So what should I look for or test?I tried to find anything labeled ps/on and tried pressing the power on and testing each wire but no change in volts?
    I did find this tv at work laying on the ground face up.Work for college apartment complex.We find stuff like this all the time and hoped some of it can be repaired.
    Looks like they are made by haier and sale for 200 new.So wouldn't want to spend more than 100 trying to fix it.
  • Papajohn
    • Jan 2014
    • 13
    Re: Vidao 32E66 will not turn on
    Pcb:mib323d
    • Papajohn
      • Jan 2014
      • 13
      Back
      • selldoor
        Slow Learner
        • 7870
        So heading is misleading - it does turn on but no picture.
        Have you a source connected - a video playing might be good.
        Is there any sound - try cycling through the source/input as you wont know what it is on at the moment.
        Close up in focus pictures of each board would help
        • Papajohn
          • Jan 2014
          • 13
          Pcb
          • Papajohn
            • Jan 2014
            • 13
            Main
            • Papajohn
              • Jan 2014
              • 13
              Shouldn't the orange light change color when hitting the power button?Even with nothing connected.
              • Papajohn
                • Jan 2014
                • 13
                Tried connecting DVD player nothing on screen also no sound.Orange power light stayed the same.
                • selldoor
                  Slow Learner
                  • 7870
                  Ok - Did you cycle through the inputs when you had the dvd connected?
                  Can you report all the voltages on each pin on con4 relative to aground screw. - You need to do this with all connectors in place.
                  Have you seen the back lights flash at any time?
                  Often on combined power/inverter boards there is a fuse connecting the two but I can see one. May be on the back of the board - can we have picture
                  of that please.
                    STB pin is the PS_ON pin. So the LED is on orange the minute you plug the TV into the outlet, and when you hit the power button, it still stays orange?
                    • Papajohn
                      • Jan 2014
                      • 13
                      of that please.
                      Yes tried biting the input button but no picture on screen at all.Tried the ch and vol also.
                      Con4 would that be the main plug going in between each board?The large and small ones are marked on the board 5v,24v,12v each had matching volts between what was marked and at the pin.
                      Only thing I seen close to a fuse but not sure is the yellow box in the lower right corner of the yellow board,but it seemed to be soldered to the board??
                      • Papajohn
                        • Jan 2014
                        • 13
                        Yes soon as I plug the tv in the light turns orange and never changes color or flickers while pressing any buttons.
                        Also tried plugging it in and turning on in a dark room to look for any glow and can't see anything.Tried holding power for 30 seconds also didn't help.
                        • selldoor
                          Slow Learner
                          • 7870
                          No - yellow box is not a fuse - there is a black one right at the end but that must be ok. I am now looking for one on the back of the board - please post a clear picture.
                          Is there no flash at all from the screen - obviously you need the lamps plugged in.
                          You could also test to see if there is any voltage on the capacitor in the middle of the power board near where it says low voltage
                          The black one with a stripe - not the blue one.. We ask for clear pictures so we can see the part numbers makes it a lot easier.
                          Yes I meant the long connector to the main board please re test as I said and post results as
                          Pin1 - 0v
                          Pin2- 5v and so on
                          • Papajohn
                            • Jan 2014
                            • 13
                            Yellow board part number is mib323d.No flash from screen.
                            I will test voltage when I get home from work today.I will try to get a better picture using iPhone 4 to take them.
                            • Papajohn
                              • Jan 2014
                              • 13
                              Thank you for the help so far.
                              • im_trying
                                MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
                                by im_trying
                                Hi, thanks for helping.
                                The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
                                For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
                                I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
                                The photo below shows this better than words.
                                Thanks for anyone...
                                05-12-2025, 04:16 AM
                              • pajdek
                                Lenovo Y700-17ISK turn on and off
                                by pajdek
                                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                09-20-2023, 02:49 AM
                              • u666sa
                                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                by u666sa
                                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                Platform: ipa32 la-m024p rev 1b
                                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                I found a short on the other side:
                                10-04-2025, 05:03 PM
                              • Mark R
                                The Overseas Only Kenwood Model KR 790
                                by Mark R
                                I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                                The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                                09-23-2025, 08:27 PM
                              • fab13
                                Sapphire RX 480 - 8go no power - 0 volts à +VDDC - Help to find why
                                by fab13
                                Sapphire RX 480 - 8GB no power - 0 volts to +VDC
                                Hello to all =D
                                I would like to start this card again for my little brother.
                                Symptoms :
                                No power on , no rgb led , black screen , no rotating fan.
                                What I found before disassembly a 22uF capacitor on the +VDDCI line was loose. Before powering up and checking if the component was missing, the capacitor was replaced.
                                Then powering up
                                +12V ok
                                +5 Volts ok
                                +1.5 V ok
                                + 0.90 ok
                                What I found abnormal :
                                -No 0 Volt on the +VDDC line...
                                01-16-2022, 05:32 PM
