viore LED42VF80 flat screen tv shuts off after about a hour
  • leo25
    • Dec 2013
    • 17
    • United states
    So I have this 42" viore lcd tv. Its works great for about an hour and shuts off on its own. Try to tuen it back on and it brings the logo up and shuts back off when it dose this the screen looks a little dark in the corners too. Im assuming something is over heating and causeing it to shut down. Once it cools down the tv will work again about an hour. I have opened it up removed the power board and have tested all the caps with a peak atlas esr meter and all good. There are about 4 transistors on 2 sepret heat sinks im hoping these might be the problem just waiting for a transistor tester in the mail. Anyone have any ideas what to look for or a possible fix for this?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: viore LED42VF80 flat screen tv shuts off after about a hour
    Suggest you put it back together and switch it on - heat each board in turn gently with a hairdryer and if it is heat related the set should switch off sooner.
    When you have the board try and narrow the problem down to a component.
    Check thoroughly for bad solder joints
    • leo25
      • Dec 2013
      • 17
      • United states
      Is it possible the t-con board can do this because besides the power board there is only the main board wich shouldnt cause it
        Main boards can and often do cause this problem.
        • leo25
          • Dec 2013
          • 17
          • United states
          So I should heat up each board individualy with a hair dryer and see which on causes the tv to shut down and go from there?
            Yeah, I would try that.
            • leo25
              • Dec 2013
              • 17
              • United states
              No response with the hair dryer
              • leo25
                • Dec 2013
                • 17
                • United states
                It just shut off again by itself I think its a transistor one of them thats by itself on a heatsink after the tv shut off I felt the heatsink and its extremely hot compaired to another heatsink that has 3 transistors on it and it didnt feel to hot at all.
                • leo25
                  • Dec 2013
                  • 17
                  • United states
                  Whatever is going on though its messing with what makes the screen light up. There are four plugs on the power board which run to the screen to power it on. Of u unplug one at a time u see a different corner of the screen is dark. Well after this darn thing shuts off on its own and u try to turn it back on the bottom left corner of the screen looks dark the tv shows the viore logo and shuts back off. Once it all cools down it powers on fine and the screen looks ok
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    I Have changed this - didnt realise it was LED Doh
                    It sounds as though there may be a faulty wiring connection to the bottom left hand bulb. Also if they will reach swap over a pair of wires and see if the fault moves.
                    • CraigR
                      • Dec 2013
                      • 973
                      is that socket CONF5?
                      • leo25
                        • Dec 2013
                        • 17
                        • United states
                        It was just something I notice after I try to turn it on I noticed it before it shut off again it dosent look like that threw the time of the initial power up and for the almost an hour it would stay on. What did u have to change?
                        • mecelprimo
                          • May 2014
                          Hi i have the same exact problem anyone can help please viore42
                          • bwcbob
                            • Feb 2009
                            Dead unit even with a new power supply, We have found that the problem is inside the LED panel, To be more specific the red B+ wire on the led strips is touching the aluminum ground plane on one or more LED strips, To verify without taking the panel apart just disconnect the 4 sockets and measure for a short across the pins, If shorted then the problem is inside the panel.
                            Reason of failure is the close manufacturing tolerances, The Plexiglas reflector is to big and the corners right on the top of the solder connections are pushing against the red B+ wire on the left and right strips thus creating a short.
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • SarcasticOP
                              iPad Pro 12.9 (6th Gen) screen shuts off after unplugging device
                              by SarcasticOP
                              Greetings,
                              I have an iPad Pro 12.9" 6th gen tablet that had a screen replaced about 10 months ago at a repair shop and last week the screen went blank during use. The device was still on, notifications played sound for example. I have replaced the screen twice, both screens are working until I unplug it, at which point I can see that screen is on but is all black. If I press the power button, the backlight goes off, and when I press it again, the image appears for half a second and then the screen goes back to being black but on. This issue is not present at all when the iPad...
                              10-24-2024, 11:55 AM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
