I've attached a photo of what my screen looks like. I've pulled it apart and don't see anything obvious like blown caps or loose connections. It's a Hitachi 40" LCD model number, L40C205. Basically shows a red and blue tint like a 3D TV that's not. Any help would be greatly appreciated!
Hitachi 40" LCD L40C205
Re: Hitachi 40" LCD L40C205
I have tried re-seating the cable to the T-CON but not from the T-Con to the Panel, the T-Con is at the very top and kinda of hidden. I will take it apart again and try that, and get the make of the Panel itself. Thanks for the help!Comment
Did the fault occur suddenly or slowly get worse? Is it always present or only there after warming up?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Well if it happened suddenly, it could be a corrupted EEPROM setting.
As this isn't a real Hitachi inside (just a rebadge) it is necessary to determine the service menu procedure.
I would try the following, on the remote
SOURCE/INPUT 2850
SOURCE/INPUT 2580
and any others here
https://www.badcaps.net/forum/showthread.php?t=24809
to see if you can locate a reset option.
I notice main board is made by AoH(?) which may give clue to the service access code.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
So one of those sequences enters the service/factory mode?
Note: factory reset from user menu is NOT the same.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
All of the buttons will be on the remote. Press in sequence rapidly. However, I cannot guarantee it will work. One other possibility:
SOURCE/INPUT 3690Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I can't offer many other suggestions unless anyone knows the service menu code for this. You can try (and this might not work) asking Hitachi. However they might only tell you if you are a TV technician.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I've been digging around the Internet and can't find much, it is rebranded, parts from all manufacturers. I'll try again this weekend, busy work week. Most Hitachi codes or resets are from several years ago. Thanks again for all the help!!Comment
I suspect while it is a rebadge, it is custom for Hitachi, i.e. custom main board or at least part#.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by massimomaxChiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
by fharris1977Hello. I have this hitachi with no backlight and it needs this transformer. Does anyone know where this transformer is sold and can please provide a link if so? I have entered the part number with no luck....
by dragometinTV Model: Hitachi 40HYC42
Power Supply: 17IPS71
MainBoard: 17MB95M
Panel: VES400UNDS-2D-NO3
When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
Is there any variants on 17IPS71 power supply's?
UART output pins 10 and 12 on scart connector:
Code:12:24:04.595
- Loading...
