Time for me to restock on capacitors. I had a stock of Rubycon YXF capacitors that I've been using to revive LCD tvs, but I've run out. Anyone have any opinions as to whether the ZLJ versions would be better or worse for this application?
Rubycon YXF or ZLJ Capacitors for Power supplies?
Re: Rubycon YXF or ZLJ Capacitors for Power supplies?
ZLJ can work in some applications but in general are best for motherboards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I think YXF is non-aqueous electrolyte and ZLJ is aqueous electrolyte... The consensus here is that non-aqueous caps should last longer in PSUs eventhough they have lower endurance ratings than aqueous caps... I would still personally prefer ZLx though.Comment
Based on the assumption that YXx series are comparable to Panasonic FC/Nichicon PW and that ZLx series are comparable to Chemi-Con KY (Which has an aqueous electrolyte).
If you have any concrete information that states otherwise, please post it.Comment
Close. ZL_ is more like NCC KZE, KZH or KZN. Ruby's equivalent to KY is YXG.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
YXH is probably the closest (at least when comparing the common 2200uF 6.3V in 10x25mm), but they don't have an exact match.
YXJ caps are physically smaller for the same capacitance and voltage compared to YXH, and thus have a higher ESR and lower ripple.I love putting bad caps and flat batteries in fire and watching them explode!!
Yea, but is YXH aqueous electrolyte, or is it equivalent to LXZ/FC/PW in that aspect?Comment
No Idea. I would guess that it's non-aqueous, but that's only based on the fact that its electrical specs are similar to FC.I love putting bad caps and flat batteries in fire and watching them explode!!
Makes sense.
I thought YXH was a newer series, but it appears that you're right... Haven't seen it that often though, but YXG was plenty popular, even as far back as 2000, possibly earlier.Comment
kind of obsolete info given the price drop on cheap wurth-electronik poly's recently.
you can even get 2000uf or 63v ones now.
not in that combination yet though.
http://katalog.we-online.de/en/pbs/b..._KondensatorenLast edited by stj; 03-25-2015, 02:07 AM.Comment
Assuming...7 Photos -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
