Rubycon YXF or ZLJ Capacitors for Power supplies?
  • Maxstang
    • 61
    Time for me to restock on capacitors. I had a stock of Rubycon YXF capacitors that I've been using to revive LCD tvs, but I've run out. Anyone have any opinions as to whether the ZLJ versions would be better or worse for this application?
    Re: Rubycon YXF or ZLJ Capacitors for Power supplies?
    ZLJ can work in some applications but in general are best for motherboards.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      ZLJ and ZLH are great in power supplies, I haven't had any issues using them. Their ESR is quite a bit lower (but not ultra low) compared to YXF, but that's a good thing for PSU's.
      • mockingbird
        • Dec 2008
        • 5484
        I think YXF is non-aqueous electrolyte and ZLJ is aqueous electrolyte... The consensus here is that non-aqueous caps should last longer in PSUs eventhough they have lower endurance ratings than aqueous caps... I would still personally prefer ZLx though.
        • Maxstang
          • 61
          Great responses. Thanks guys.
          • goop
            • May 2014
            • 45
            • state
            Based on what?
            • mockingbird
              • Dec 2008
              • 5484
              Based on the assumption that YXx series are comparable to Panasonic FC/Nichicon PW and that ZLx series are comparable to Chemi-Con KY (Which has an aqueous electrolyte).
              If you have any concrete information that states otherwise, please post it.
              • c_hegge
                • Sep 2009
                • 5219
                Close. ZL_ is more like NCC KZE, KZH or KZN. Ruby's equivalent to KY is YXG.
                • mockingbird
                  • Dec 2008
                  • 5484
                  What is Rubycon's equivalent of PW/LXZ/FC?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    YXH is probably the closest (at least when comparing the common 2200uF 6.3V in 10x25mm), but they don't have an exact match.
                    YXJ caps are physically smaller for the same capacitance and voltage compared to YXH, and thus have a higher ESR and lower ripple.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Yea, but is YXH aqueous electrolyte, or is it equivalent to LXZ/FC/PW in that aspect?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        No Idea. I would guess that it's non-aqueous, but that's only based on the fact that its electrical specs are similar to FC.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Makes sense.
                          I thought YXH was a newer series, but it appears that you're right... Haven't seen it that often though, but YXG was plenty popular, even as far back as 2000, possibly earlier.
                            • 30940
                            kind of obsolete info given the price drop on cheap wurth-electronik poly's recently.
                            you can even get 2000uf or 63v ones now.
                            not in that combination yet though.
                            http://katalog.we-online.de/en/pbs/b..._Kondensatoren
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                              by sam_sam_sam
                              After all of...
                              07-13-2024, 08:14 PM
                              09-06-2024, 05:59 AM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
