Panasonic TH-L37U20A Blown Rectifier?
  • max1636
    • Dec 2013
    • 80
    I've got a Panasonic TH-L37U20A which I've taken apart from found a blown rectifier, seen here:
    http://i1208.photobucket.com/albums/...psae37723c.jpg
    http://i1208.photobucket.com/albums/...ps8109d2fe.jpg
    It's also blown the main fuse with it but thats no problem the issue is I don't know where to find a replacement that's exactly the same.
    To save you looking at the pictures the chip reads S1WB (1st Line), S80 04 (2nd Line), the closest thing I could find is this one on eBay:
    http://www.ebay.com/itm/S1WB60-Manu-...:X:RTQ:US:1123
    But the second line doesn't match. Where can I find a replacement?
  • max1636
    • Dec 2013
    • 80
    Re: Panasonic TH-L37U20A Blown Rectifier?
    I have some of these sitting around:
    http://www.goldmine-elec-products.co...es/G18636B.jpg
    I don't suppose I could use one of them If I extended the connections out or something?
    • R_J
      • 9628
      Its a 800 volt 1 amp bridge rectifier, Should be able to get one anywhere.
      http://www.digikey.ca/product-search...=0&pageSize=25
      That large bridge you have would work but would be a pain in the ... to mount it.
      • Lee M.
        IR night vision goggles to find shorted panel line?
        by Lee M.
        Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
        11-10-2023, 03:19 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • mikkele86
        Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
        by mikkele86
        hello.
        I have two power amplifiers, both having their IGBT blown on the PSU.
        The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
        I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
        I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
        So I though i missed a capacitor or diode. I removed...
        01-06-2024, 06:45 AM
        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
        by momaka
        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
        http://www.rmac.kingwin.com/products.../abt_650MM.asp
        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
        What mostly drew me into buying it is its 2x PCI-E power connectors...
        03-29-2022, 11:34 PM
      • Raygen
        No VCC to bios chip - Huawei Matebook d15 DAH98AMBAD0 REV:D HF Model H98A H898A
        by Raygen
        Hello, I received to repair this Huawei laptop (model in the title).
        The laptop will charge the battery fine throught the USB C port, but it wont turn on. The charging led will blink fast and repeatedly when trying to turn it on.
        I've attached photos of the board. (the wires are for briging the power button, I did not inject voltage)
        Upon visual inspection, a couple of ICs were blown. Along the 5V line leading to one of the USB A ports. They wasnt fully shorted but just a couple of ohms to ground.
        I replaced the blown IC on the board (the one circled in red,...
        09-23-2024, 04:21 PM
