IR night vision goggles to find shorted panel line?
  • Lee M.
    • Nov 2021
    • 35
    Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
  • Diah
    • Feb 2013
    • 6404
    Re: IR night vision goggles to find shorted panel line?
    lines on ribbon will never heated... the parts before or after connection point will heat up such in yours questions example the COF will be before and Gate cells on Panel will be the after
    also lines will burn if the ohm exceeded cause of short
    • Yanleb
      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
      by Yanleb
      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
      D608, good
      D618 RF101L4S, good (See warning 1 below)
      D619 RF101L4S, good (See warning 1 below)
      D865 RF101L4S, shorted (See warning 1 below)
      IC464 Inverter HA MC74HC1G14, shorted...
      03-09-2020, 12:00 AM
    • Mousetohome
      PS5 Shorted power button line
      by Mousetohome
      I been trying to trace this via for a few hours now, Could someone tell me what Chip gets Ground to power up the console? Or maybe about where it should go? This is from a EDM-033 but i would imagine most are the same....
      09-21-2024, 01:43 PM
    • kalilinux25
      LENOVO Shorted +5VALW AND +3VALW LINE ACLU9/ACLU0 NM-A311
      by kalilinux25
      Hi good day to all hope someone can give me some advice whats happening to this board.
      Ive check the output voltage line of +5valw and +3valw all shorted I thought I was having a SIO shorted to.
      I try to remove the SIO chip But still shorted I tried to check all CAPS of the pu401 and PU402 all ok
      SHORTED TO GROUND
      PL402 AND PL401 , i tried also to remove the 2 coils and test the PJ402 and PJ406 im having short at those sections,
      I hope someone can guide me if anyone, Thank You in advance...
      01-20-2021, 11:56 PM
    • modtool
      HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
      by modtool
      Hi to all,
      the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
      I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
      I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
      04-01-2025, 08:22 AM
    • BalkanBoy
      Dead Razer Blade 14 2022, shorted CPU?
      by BalkanBoy
      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
      I removed coil and injected 0.7V, it draw around...
      09-27-2024, 12:44 PM
