Samsung LE26A456C2D issues.
+ More Options
Posts
  • NeiltheDruid
    • Sep 2010
    • 42
    Hi chaps,
    My uncle has handed me this little TV for a pet project. The failure happened (as my uncle described it) as a white square in the top right corner which then spread to the rest of the screen, then the screen died.
    When you turn the screen on now, no matter which source you select, the screen displays a very thin multicoloured static line along the bottom of the screen and there is some vertical "ghosting" on the left hand side on the screen. It does still play its "splash" sound.
    I've popped the back off to have a quick look for any obvious over heating/burning or bad caps. The power supply has got a couple of suspect bulging caps, but the TV doesn't seem to have a problem at the moment with getting power.
    Would you guys think this would be a terminal panel failure or maybe a T-Con failure - or even something else.
    I would really appreciate the help!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung LE26A456C2D issues.
    Pics would help
    • NeiltheDruid
      • Sep 2010
      • 42
      Rightio mate, will get on that. Boards as well or just the screen?
      • newtothis
        • Mar 2013
        • 1556
        • england
        May as well get them all
        • NeiltheDruid
          • Sep 2010
          • 42
          Here are some pictures of the screen running. They aren't great my camera can't get decent light with the rubbish weather at the moment and if I used the flash it masks the problem with the screen, but I think you get the idea.
          The screen has the white ghosting after a couple of minutes turned on. It's much more noticeable in person than in the photo. Its is mostly on the left side of the screen, there is some that protrudes into the right half of the screen. The line I was talking about, at the bottom of the screen seems to only come from one source (pressing the source button on the side removes the line until the tv has cycled back round).
          I will try to get some pictures of the boards when the light is better
          • johnboy1313
            • Nov 2012
            • 1959
            Chances are high that you are dealing with a similar problem.
            https://www.badcaps.net/forum/showthread.php?t=33833
            • NeiltheDruid
              • Sep 2010
              • 42
              Hi johnboy1313. Is it possible for tab bonds to cause a completely blank screen?
              • newtothis
                • Mar 2013
                • 1556
                • england
                Yes it is, Can you just disconnect the tcon and see what shows on screen
                • NeiltheDruid
                  • Sep 2010
                  • 42
                  hi newtothis,
                  I disconnected what I believe to be the T-Con from the main board (the one with the I/O ports). The screen goes completely black, no white, no line along the bottom, but I'm pretty sure that's because the signal has been totally broken to the panel.
                  I looked this board up on ebay where it is reffered to as a "display driver" The chain the boards run in are power supply -> main board -> "Display driver"(?) -> Panel. Unless there is another board that is buried under the shielding that I am missing.
                  Sorry if I'm doing this wrong, I am truly new to this.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    yes thats the correct board.
                    • NeiltheDruid
                      • Sep 2010
                      • 42
                      hi vinceroger69
                      Thanks for confirming that Wasn't sure if I was just being a bit thick.
                      So yes - I disconnected the T-Con from the mainboard side, not the panel side since that is a bit fiddly and is essentially the same thing anyway. The screen went totally black with just the backlight working.
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        No line... Ok instead of removing the cable that goes to the main board, try removing just one from the top of the tcon... Does that line show?
                        • NeiltheDruid
                          • Sep 2010
                          • 42
                          Hi newtothis,
                          Sorry it's taken me a while to get back to you. I've been away.
                          On the panel side of the T-con there is only one ribbon cable going to the panel, if I remove this it the panel goes blank.
                          I actually purchased a new mainboard from ebay. I stuck a really low offer on it and the guy accepted! Turns out that this board is probably faulty too. It wouldn't even play the splash sound when I switched the TV on. What I can confirm is, that changing the mainboard didn't make a bit of difference to the picture, same line along the bottom on one of the sources.
                            The "splash sound" (Melody) is a user option. Your uncle might have turned it off. You probably have a tab bond issue of some sort, though I've never seen one like that.
                            • NeiltheDruid
                              • Sep 2010
                              • 42
                              I took the screen apart to have a look at the tabs, there are two of them bonded to the glass. After poking around while the screen was turned on, I'm still not getting anything new
                                Is the panel inside made by Samsung?
                                • NeiltheDruid
                                  • Sep 2010
                                  • 42
                                  tom66,
                                  I'm not sure who the panel is made by. There are no obvious logos to say the panel is made by Samsung. The TV was built in Hungary if that helps. There is a number on the circuit board that the panel is bonded to: 260AP01S2L V3.3
                                  I don't know if that means anything to you.
                                    There's a sticker on the back of the LCD metal marked something like: AU Optronics, Samsung, Chi Mei, Chungwha Picture Tubes, etc.
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
                                    • Chrissygizmo
                                      samsung galaxy ao2s very temperamental after screen replaced
                                      by Chrissygizmo
                                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                      Ive eventually managed to get it on and working but it's very temperamental...
                                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                      05-26-2024, 12:05 AM
                                    • JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                      by JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                      Please help. Thanks in advance!
                                      08-12-2025, 11:45 AM
                                    • Kiberge
                                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                                      by Kiberge
                                      HI guys!
                                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                      04-22-2024, 11:28 AM
                                    • jkruns
                                      M1 A2338 screen and touchbar issues after cleaning up liquid damage
                                      by jkruns
                                      This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                                      My patient is an A2338 Macbook Pro M1 (late 2020).
                                      It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                                      04-22-2024, 06:45 AM
