Panasonic TX-26LXD80 - tab bonds fault (4th ChiMei V260B1 panel with same fault)
    Another ChiMei 26" 720p with a tab fault (occasional blown out image, grey/white, distorted, jumping vertically, fading in and out, freezing -- all resolving after some time.) Applying pressure to top left tab fixed issue. Twisting frame of TV occasionally fixed image. Picture for future reference.
    This panel definitely used in:
    Panasonic TX-26LXD80 (fixed two)
    LG 26LC55
    Sanyo CE26LC81-B
    I have not yet seen this fault with 32" 720p ChiMei panels.
    Thanks to a fellow badcaps member as this was a free TV.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Panasonic TX-26LXD80 - tab bonds fault (4th ChiMei V260B1 panel with same fault)
    Out of curiousity, in a previous thread, you mentioned that you had succesfully fixed bad tab bonds by re-wiring the top bonds to the side bonds (or at least that is how I interpreted it). What is the difference in construction in this panel that prevented you from doing the re-wiring thing?
    Also, out of curiousity, any chance you could post a link to the write up that you referenced in the other post? I can't find the thread, but I'll keep looking.
    • johnboy1313
      • Nov 2012
      • 1959
      https://www.badcaps.net/forum/showth...889#post398889
        I mentioned that it was an idea. Unfortunately the project TV I was planning to do it on did not have a typical tab bond fault. Instead of the bond between the tab and LCD, the fault was between the tab and chip on the tab, which the idea in question cannot fix. In fact that cannot be fixed at all, and shims will be unreliable on those.
        The suggestion of manual wiring in will be best used on panels where tab shims prove to be unreliable (but do work somewhat) such as on Samsung 32" and 40" 1080p, and LG 37" panels. Other panels it would seem a shim is the best long term solution.
        You'll notice my opinion has changed as I've had more time to think about the causes of all these LCD and LED-LCD TV faults. Shims can sometimes be long term fixes if the issue exists on the bond between the PCB and tab, but only really in that instance.
        • johnboy1313
          • Nov 2012
          • 1959
          That stinks, think of the TVs that could be saved if someone could come up with a cheap and permanent fix for bad tab bonds.
            There is a permanent fix. See here:
            http://www.youtube.com/watch?v=V04H40oO4w8
            http://www.youtube.com/watch?v=iqVU0YggPEs
            If you have to ask the price of those machines though, you can't afford one.
            Oh, and there's still the problem of getting replacement tabs, and soldering the tab back onto the driver board.
            So it's unlikely to be worth it except on 60"+ LCDs where the price might be economical.
              V260B1 panel may also be used in (not fully confirmed):
              RCA L26WD26DA - https://www.badcaps.net/forum/showthread.php?t=29607
              Element ELCHW261 - https://www.badcaps.net/forum/showthread.php?t=25943
              Sharp LC-26DV24U - https://www.badcaps.net/forum/showthread.php?t=33356
              Samsung LE26R32, LE26R81 -
              • freakaftr8
                • Oct 2012
                • 3743
                Man thats sad.. Even Panasonic uses cheap outsourced LCD panels. Guess it all started when they started putting Chinese power supplies in Plasmas...
                O well
                  This is a 2008 TV. Their newer TV line is 99% LG Display panels which are pretty good panels.
                    Also confirmed possibility:
                    LG 26LC46
                    Insignia NS-LCD26A
                    Insignia NS-LCD26-09
                    Vizio VW26L####
                    Westinghouse SK-26H590D
                    Viewsonic N2635W
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      just been watching one of your you tube videos repairing a 26in sanyo tab bond fault on that as well good video imo.
                        Yeah same panel, had 100% success on these fixes. At last check, before Sanyo sold, had played for over 5 months with no issues whatsoever.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          thats good never attempted one yet but may have mates 32in samsung with possible tab bonds fault i will post a video up as not 100% sure its a tab fault (on the bottom on this set) or a main board fault.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            I've done one of those and it can be fixed, it's not tab bonds per se. Here's a guide writen by a Romanian Samsung employee: https://cdn.badcaps-static.com/pdfs/...d70dc0a22e.pdf
                            It's delicate work but not impossible.
                            A working TV? How boring!
                            • Rictech
                              Panasonic SA-MAX770PU SMPSU board fault....
                              by Rictech
                              Hello everyone. πŸ˜€
                              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                              There are no devices that have exploded or otherwise show signs...
                              08-26-2024, 01:05 AM
                            • BigPete
                              Panasonic Heatpump Dryer Repair
                              by BigPete
                              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                              Unfortunately the whole machine has to come apart to fix it.
                              I have...
                              11-01-2025, 06:40 PM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                              11-20-2024, 08:52 PM
                            • chockimon
                              Panasonic TX-40AX630B has developed a fault
                              by chockimon
                              I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
                              I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
                              06-02-2022, 12:03 PM
                            • fixxy88
                              Panasonic 55DX600u second fault - panel brightness pulsing on right side
                              by fixxy88
                              After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
                              I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
                              03-22-2023, 02:58 AM
